I bought it and I didn't take too many pictures but I will say that you have to remove the bumper and the grill so you can easily work with the Dremel during the cutout process. I just followed the instructions on their website the only thing is where to draw power from. I put a 5amp in line fuse and for the power from the wire in the drivers side footwell. I did use the brown/yellow wire but I made the initial mistake of just going with the first one I saw(bottom set of taped together wires). There are actually two brown/yellow wires, the right brown/yellow wire that is always on with the ignition is the top set of taped together wires. So my problem is solved. If anyone needs help go ahead and message me I will be glad to help.
