So, until some... errr, recent developments, I had been planning on swapping out my stock rims for some 16lbs enkei j10s, and swapping appropriate tires on. Since a large chunk of the money I had been setting aside will be going to repairing some damage that appeared on my car after I left it parked, I’ve decided to look at other options for taking some of the harsher characteristics out of the ride.
So, let’s talk about how I drive and use the car. I’m usually pretty lax, the FiST is my daily. I do take it up onto mountain roads occasionally, but for all intents and purposes I generally use the car to commute.
That said, I’d like to soften the ride a touch, to make it a bit more bearable for my significant other (I’m tired of having to drive a prius on the weekends because my car rides too harshly in her opinion) and frankly the roads by me are rough so I’m sure I wouldn’t mind if the car were slightly softer. That said I’d like to keep the cost as low as possible due to the afore mentioned event, and that has lead me, quite comfortably to dampers... dampeners? No ones sure.
Seems like the Koni Orange STR.Ts would fit the bill since I have no plans to drop the car, was just hopping for a bit of feedback on other options (koni yellows/bilsteins etc) would compare with the stock springs. Coilovers are out of the question due to price. My suspension is fully stock with the exception that apparently the previous owner put a different front sway bar on (a later MY Fiesta ST one because apparently it’s better?) so I was just hoping for some testimony from people who have had experience with anything mentioned.
