Low boost blues
Mike King
U.S. Air Force Veteran
South Central Pennsylvania
I have the stage 2 E30 tune from Jason running and it was great for a while. I could peak at 23.88psi boost but then something happened and the best I can get it 12psi now. I made sure I am not in eco mode. Any suggestions?
Burlington, NC, USA
Do you have the data logs for the 20+ psi pull and the low boost one? If so you can compare WGDC and make sure you’re on the right tune if they match.
Boost leaks have been the culprit for me. I leak test by removing the elbow from turbo and throttle body. Cap the throttle body end and put a boost leak tester in the turbo end and put 20ish psi into it and spray with soapy water.
Mike King
Mike King
No, I had just uploaded the tune and went to a buddy's house to brag. It did a number of pulls over 20 psi but now it's 12 psi. When I can get on a lift, I will soap test everything. I feel like I shook something off or it blew off but not enough to set a CEL.
Burlington, NC, USA
Yeah most likely a boost leak somewhere. Hot side charge pipe and both intercooler hose clamps are the most likely culprits.
