I recently opened my shop selling car accessories for two of my favorite cars, the Fiesta ST MK 7.5 and the Mitsubishi Lancer Evo IX.
I've scanned and desiged these products for personal use initially but soon realised that I'd like to share these designs across the world (well EU for now lol).
These are all 3D Printed in ASA material for better UV Resistance ( up to 85 degrees Celsius ) and have been thoroughly used and tested in all driving conditions.
You can visit my shop at 777engineering.eu or check out my instagram page at 777.engineering for more info and to make a purchase if you'd like!
Magsafe Charger Phone Mount
This Magsafe mount is designed to make use of the ST180 Mk7.5 cubby hole that doesn't have any real use.
Well now it does!
IMPORTANT
Made with premium UV resistant ASA plastic and with 3d scanned precision, the mount fits nicely into the cubby hole and with the help of some double-sided tape (included) it looks OEM.
-It's available for both RHD and LHD
-The magsafe charger (NOT INCLUDED) fits snug into the insert without any use of tape and the hole in the middle is for ease of removal.
-This product has been tested and tried out in different driving conditions and the magsafe charger's magnet itself has no problem holding your iPhone in place.
-The mount is also tilted towards the driver for better visibility/
Please note :
-Use the Magsafe charger only with compatible Magsafe cases or without any case.
-In order for the Magsafe charger to work you need to have a cigarette lighter adaptor with a USB-C port.
-Magsafe charger is NOT included.
-There are TWO types of Magsafe chargers, please identify which one you have , the newer versions have a braided cable.
GoPro/Insta360 Headrest Camera Mount
Capture everything from trackdays to relaxing drives with this headrest GoPro / Insta 360 camera mount.
Made with 3d scanned precision and with premium UV resistant ASA plastic this camera mount provides a steady view from the car's cockpit onto the road providing a wide angle similar to onboard rally cameras.
Perfect for content creators and video enthusiasts!
Assembly is very easy, just remove the headrest and slide the mount on.
NOTE: To remove the headrest you have to press both buttons on the plastic clips (there is a small button that only needs to be pressed to remove the headrest completely)
It is recommended to place on the co-driver seat
KEY FEATURES
-Fits Ford Fiesta Mk7.5 ST180 Recaro Seats and Ford Focus ST MK3 Recaro Seats
-UV Resistant (up to 85 Degrees Celsius)
-Set and forget design , doesn't interfere with helmets/co-driver
-Easy assembly / dissasembly -Durable material ( ASA )
-Steady design
-Can be used with any camera that uses GoPro type mounting
INCLUDED
-Camera Mount
-GoPro type Bolt
I can only ship to the EU and UK for now although I am looking for solutions for the US
There's more products coming very soon!
Thank you for your time !
Well now it does!
IMPORTANT
Please note :
KEY FEATURES
-Steady design
INCLUDED
-Camera Mount
-GoPro type Bolt
