Going something a bit wilder now so these are no longer needed.
Beam will allow full air flow when you open up the grill, if needed I can weld in a tube to add more strength for a bit extra cost. Full perimeter filler stitch welded in place where beam material was removed. Mounting ends modded a bit for my CIA intake feed but still more than solid enough to mount to chassis.
Beam has drilled for lower weight, braced, J-Line IC mounts welded to the back side,
Very restrictive stock crash sensor mount replacement which is lower in weight and far less restrictive. It has tabs to bolt on a Setrab or other oil cooler of the same size.
Includes custom hood latch support bar
$299 for all three parts, will consider separating them, there is at least 12 hours of work into these parts so this is a great deal and direct bolt on.
UPDATE: I am not going to be able to ship for at least 8 more days, likely 10 days as out of town and they parts are on the car back home. Shipping is not included in the price but I have several shipping accounts to check on. Also I need to measure and weight the parts, which I would ship together of course.
Thanks
Rick
Thanks
Rick
