FYI....
Mountune releases 2 new lines of High Performance Brake Pads , available in two compounds for both Fiesta ST and Focus ST....
https://www.facebook.com/7238038876...803887634561/1078447152170231/?type=1&theater
[HR][/HR]
RS-R Series:
High performance road application.
Mountune RS-R High Performance Brake Pads have been developed to offer outstanding performance over a wide range of driving conditions. Engineered to our specifications exclusively by Hawk, the RS-R pad has been optimized with increased friction yet remaining essentially dust free. The Ferro-Carbon formula yields up to 40% greater stopping power without increased noise. This is the perfect pad compound for aggressive driving while remaining gentle on the brake rotors.
Front:
http://www.mountuneusa.com/mountune-RS-R-Front-Brake-Pad-Set-Fiesta-ST-2013-p/7064-bpf-a1.htm
Rear:
http://www.mountuneusa.com/mountune-RS-R-Rear-Brake-Pad-Set-Fiesta-ST-2013-15-p/7064-bpr-a1.htm
[HR][/HR]
RS-T Series:
Track and Autocross Use.
Mountune RS-T High Performance Brake Pads have been developed to offer outstanding performance for not only severe road use but extended track applications as well. Engineered to our specifications exclusively by Hawk, the RS-T pad has been optimized with an extremely high coefficeint of friction that is fade resistant under repetitive heavy braking. The broad temperature range of this pad means that it can be used in a wide range of applications including high powered street cars looking for dramatically increased stopping power. These pads feature a smooth and consistent feel and bite and remain functional under the most extreme conditions.
This pad compound is an ideal upgrade for use in Autocross, Solo II and track day applications.
While this pad can be used for street driven vehicles, there is an increase in noise, dust, and rotor wear.
Front:
http://www.mountuneusa.com/mountune-RS-T-Front-Brake-Pad-Set-Fiesta-ST-2013-p/7064-bpf-a2.htm
Rear:
http://www.mountuneusa.com/mountune-RS-T-Rear-Brake-Pad-Set-Fiesta-ST-2013-p/7064-bpr-a2.htm
[HR][/HR]
[HR][/HR]
RS-R Series:
- Quiet operation
- Very low dust
- Excellent performance
- Perfect fit
- Easy on brake rotors
- Minimal fade under extreme temperatures
- Ferro-Carbon compound
Front:
Rear:
[HR][/HR]
RS-T Series:
- Excellent performance for Track and Autocross
- Perfect fit
- Extremely high friction
Front:
Rear:
[HR][/HR]
