Oil recommendations
I live in S. Fl.... so warmer temp year round. I will soon own a 2014 Fiesta ST. I believe the manufacture recommends a 5w - 20 full synthetic... Isn't 20a little light for a turbo charged engine? In my mini cooper S with the 1.6L turbo I was told by my mechanic who specializes in such vehicles to use 5W-40 liquimoly in my turbo cooper vs 5W-30... why does the factory recommendation have such a low viscosity to a similar sized turbo engine in another car?
SteveS
Synthetics keep their viscosity levels better at temperature extremes than mineral oil. That's why the recommended viscosities are lower than what used to be recommended with mineral oils. The lower viscosity also aids in fuel economy.
green_henry
I switched to 5-30 on my last oil change and plan to stick with that going forward. It's slightly quieter now, and any difference in mileage has been negligible.
felopr
I live in Puerto Rico and i have found the car likes better 5w30. Europe's stock oil weight is 5w-30. They use 5w-20 because of fuel mileage.
FiSTerMr
Pennzoil Platinum 5W30. Yearound. Location: Northeast.
Been using it since 2500mi, now at 13k miles.
Purrs like a kitten.
OEM filter, OEM size.
Oil change every 3k miles... I know I'm crazy, but oil is cheap (Wally World has the stuff for roughly $25, and can be had even cheaper when penz does rebates) and worth the piece of mind, imho.
2017 w/Recaros - bone stock
koozy
0w-40 Castrol Edge. I break rules.
Sent from my iPhone 11 Pro Max using Tapatalk
5w20 Castrol Edge and motorcraft FL910S filter. 5k intervals, oil comes out clean and a medium brown every time. FWIW my car is mostly a daily with occasional canyon runs. Never been raced or tracked.
B
Is there any harm in using 5w - 30....I think the temp generated by the turbo would wear out such a light oil quickly
B
right thats what i figured.... I didnt get the car for its fuel mileage, I got it for its turbo charged fun factor. I think 5w - 20 is too light for the stress. I just didnt know if the car was designed to run with lighter oil and a thicker one would cause problems. I will switch next oil change
Flaco
Been using Castrol 5w30 for 30k miles. I prefer it to 5w20, its just like water to me. I've experienced no difference in mpg. And no issues.
I live in S. Fl.... so warmer temp year round. I will soon own a 2014 Fiesta ST. I believe the manufacture recommends a 5w - 20 full synthetic... Isn't 20a little light for a turbo charged engine? In my mini cooper S with the 1.6L turbo I was told by my mechanic who specializes in such vehicles to use 5W-40 liquimoly in my turbo cooper vs 5W-30 bentley service dubai... why does the factory recommendation have such a low viscosity to a similar sized turbo engine in another car?
Hi. i was looking for some help. I have a E12 1.5dci and was wondering what oil you all use its at the 80k mark and ive been using 5W30 C3 and been told using 5w40 C3 is better oil but was wondering what you all use any help would be appreciated.
