Paging all physics majors
Rocketst
Chesapeake, VA, USA
Hey guys, I need an equation that will allow me to calculate how much heat my turbo is creating under boost at various psi. I'm trying to create an air to water intercooler system that will allow the car to see 1-3 degrees above ambient temperature when exposed to 36 psi of boost. I need to know how much btu it will create so I can buy an adequate heat sink.
Sent from my IN2019 using Tapatalk
R
Rocketst
Chesapeake, VA, USA
Thread Starter #2
I'll be plumbing this system with 3/4 to 1 1/4 inch silicon hose, using a 24.7 gph pump and haven't decided on the actually intercooler yet. I need to figure out the specifics on the heat exchanger first.
the duke
Cleveland
At face value this is incredibly simple. What is the temp pre/post turbo. That's the temperature delta.
Am I missing what you're asking?
-Wait, you asking hypothetical, not actual? You're not running 36PSI currently? Oh, you need to calcualted temperature to size an aftercooler. I thought this was all running in your car.
Use PV=NRT (Ideal Gas Law).
https://en.wikipedia.org/wiki/Ideal_gas_law
You should be able to calculate the temperature differential based on compression. Compress gas "X" to 35 PSI equates to a rise of "Y" thermal units provided the volume remains constant. This in turn can be converted into BPU from the temperature. IF you're really concerned you also should take a look at gas velocity pre/post IC based on heat loss. Also, if the chamber is large enough and the deltas are great enough, you could run into condensation and such in/post aftercooler.
R
Rocketst
Chesapeake, VA, USA
Thanks man that's exactly what I was asking for.
R
Rocketst
Chesapeake, VA, USA
Alright so temp out the turbo is 289.73 degrees f thanks man
the duke
Cleveland
Sounds about right. If anything it sounds like a realistic estimate.
Again, the compressor map can show what the flow rate at 35psi will be, that should help size the heat exchanger.
San Jose
I mean the ideal gas law helps to an extent but this is more of a thermodynamics question, meaning he’d want Q=McAt
It’s a question of specific heat capacity, he wants to know how much water he’d need to keep the delta in temperature as little as possible.
Now, the ideal gas law **should** give you an idea of what your initial temperature would be prior to the charge air hitting the intercooler, however if there is a temp sensor there, that would be ideal data to use rather than a rough calculation. Not to mention, PV=nRT would be hard to use because our volume is changing depending on both on the phase of the crankshaft and on whatever the diverter valve or wastegate are doing. Those factors would make that a much more complex way of calculating the temperature, and thus the heat he needs to remove from the charge air. Not to mention, the n component of the ideal gas law would be difficult to pin down accurately unless all of your other variables are given, and we’ve already sort of discussed how they aren’t.
So, specific heat capacity of water (at 1 atm and 20 degrees Celsius) is about 4.182 Joules/(gram*degree Celsius) so your essentially trying to find the mass (and therefore the quantity) of water necessary to absorb the heat given off, and you’d then have to have a heat exchanger that could take that heat energy and radiate it, which is gonna be another Q=mcAt equation.
Essentially, what OP wants is to calculate the heat (Q) of the charge air, use that value of Q to calculate the mass (m) of water that would be required to absorb the heat and then they’d need to determine how much heat (Q) the heat exchanger/radiator portion of his proposed aux cooling system would need to radiate so as to cool the water off well enough.
The latchkey here is the heat exchanger that will be radiating the heat from the water out into the air. Even with a ton of water (which gets heavy quickly) without an efficient enough exchanger your just going to delay heat soak rather than prevent it. It’s entirely possible, with a solid radiator that sees airflow and a strong pump that the actual quantity of water necessary to achieve the stated goal would be relatively small.
But yeah, to answer the original question, the first law of thermodynamics would be your friend. The problem lies in what is determined to be an ‘adequate’ heat sink. Most radiators are gonna be entirely dependent on the airflow they receive, assuming the new water jacket intercooler would be mounted elsewhere in the engine bay you could theoretically place the radiator(s?) for the separate cooling circuit where the front mount intercooler go, but again this would be a really complex fix for something that can be handled pretty well by a standard air to air intercooler.
