Please help guys
united Kingdom
Hey
Had my meister r setup today
Running -2 camber and -2 toe
corner weighted also
The trouble is that I preferred my previous setup on standard dampers and eibah lowering springs
This setup at the moment seems like high speed traction and accelerate has a lot less traction
Is this normal
No idea what my previous setup was probably something like -1 camber and no toe
SteveS
Osage Beach, MO, USA
Why did you go with a toe setting other than 0? If -2 (what units?) means toe out, I don't think the Fiesta ST needs that.
An extra degree of negative camber shouldn't totally kill traction.
L
united Kingdom
This wasnt my idea bud this was the guys who set it up for fast road
Will be going back to 0 toe
Do you think the toe is destroying my traction maybe
Getting a lot more wheel hop
Tyres are spinning when applying power in the bends.. it never use to do this
For the record I have a lsd and upgraded rear motor mount
SteveS
In addition to the alignment settings, you should also look at the damper settings. Too stiff will likely reduce traction, as it doesn't allow the wheel to move over road irregularities, and may also prevent roll.
L
united Kingdom
Thankyou
Do you have a good recommendation for a fast road setup for the camber for handling and without messing up acceleration traction
Mike King
U.S. Air Force Veteran
South Central Pennsylvania
If your contact patch is not flat all the way across then you will lose traction. If you toe out and have negative camber then your patch is only flat on the outside tire in a very sharp turn. This means you only have good traction on that one outside tire. The inside one will want to spin because it's basically riding on the inside edge sidewall. Even in straight line digs, you are riding on the inside edge of both front tires and the tires are already scrubbing or losing traction because of the toe. Bottom line is this is more setup for a tight, slow autocross course. Just my opinion. Take a chalk, mark the sidewall and tread where they meet on the outside edge. Go drive the course you want setup for then observe where the chalk is removed. Adjust your camber accordingly.
SteveS
I think you should have the alignment adjusted for the toe back to 0 and the camber can be left at -2 degrees. But try softening the rebound on the shocks. My guess is it's too stiff, which can make the car feel like its skating in corners because it's not compliant enough. Also check tire pressures.
