Hey everyone,
So I just installed a Mishimoto Intercooler on the car and everything seems fine the only issue (not sure if its an issue) is that my boost gauge on the accessport is reading -5 while lightly on the gas (3500 rpm) use to be around -8 cruising around. Off the throttle while cruising it drops to -10 (which I believed to be normal before just means engine is creating a vacuum like it should) boosting seems great (16psi) overboost seems great (21psi) but the turbo is a little louder than before which I have read could be the turbo working harder to compensate due to a boost leak. I don't notice a drop in power or lag. I just dont know if anyone else has seen a change in boost pressure (assuming there is no leak involved) when changing intercooler systems. The only change I have noticed is boost pressure while cruising and turbo being a little louder. So basically what im asking is do these cruising numbers seem normal? Please help and thank you if you took the time to read this!
