Power Windows Fuse
XuperXero
Wuxi
Just booked appointment with Ford dealership to install 3M tint. However, I recall you're not allowed to open the windows for at least a week. A trick I used to do is to pull the fuse for power windows on my previous cars. However, looking at the manual and fuse box, I haven't manage to find it?
stuntdoogie
NYC
Couldnt find it either back when I installed tints in december so I just put blue masking tape over the buttons to remind me not to touch.
XuperXero
XuperXero
Wuxi
Glad to know I'm not the only one. I'll be taping my window switches as well. I wonder what Ford's alternative for the fuses is? Couldn't find relay for it either.
rodmoe
wausau
Try F34 Master window control switch, Passenger door window control switch
In the Central Junction Box . It is listed as a 30 amp fuse.
Not to be confused with e the F34 in the Battery Junction Box that uses F34 as Body Control Module (BCM) - Heated backlite and is a 20 amp fuse
But I bet Tape is easier to figure out ...
Perry
Leawood
"No, no, the OTHER F34."
This is the sort of stupid thing that drives me crazy. Put a different number on it, fer the luvapete!
XuperXero
XuperXero
Wuxi
Thanks for the help. Ford actually had their own massive thick sticker over the window switches.
After testing it a couple of times (I normally have to open my window to scan my card to enter/exit my apartments), the sticker works... then comes the swearing then opening door to scan card.
