Rear axel question
Maddogg22
Niles, MI, USA
I just bought an 2015 Fiesta ST, and love it! One problem is I have a rear axle that needs to be replaced. I can find a standard rear axle pretty easily but the ST is a more difficult. Can anyone tell me what's the difference between the standard Fiesta rear axle and the ST rear axle ?? Is it geometrically different or is it just the bushings? Thanks!
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The parts between ST and non ST are different,(not sure what).
Below are the part numbers for your car from Tasca Parts.
I would suggest you call Tasca (ask for Steve Powell 800-598-1484) and give them your VIN# to make sure you will get the correct parts.
No.Part #DescriptionList PricePrice N/A C1BZ-5A968-A Knuckle
FIESTA; W/ ST MODEL; RIGHT
$45.40$31.60 N/A C1BZ-5A969-A Knuckle
FIESTA; W/ ST MODEL; LEFT
$45.40$31.60 N/A BE8Z-1215-C Wheel Bearing
Rear Wheel Bearing
FIESTA; W/ ST MODEL
$129.80$79.96 N/A B1BZ-1104-B Hub
Rear Hub
FIESTA; W/ ST MODEL
$129.80$79.96
You can get an additional discount as well
jeffreylyon
Pittsburgh
The non-ST axel is not as stiff and has slightly different camber (more, I think). There are rally guys on this board that have made the switch.
