Rounded downpipe to resonator nuts even after pb blaster
Lbeau95
Québec, QC, Canada
Hi there, was trying to install my cat back and have completely rounded the two nuts on the studs connecting the downpipe to the resonator even after soaking with pb blaster . What is my best option here ? Grind off studs and use new bolts ? Will the studs come out etc....
Thankyou!
green_henry
Pleasant Hill, CA
Is there enough room to use a vice-grip? Also, pb blaster sometimes needs a little help, so if you can tap the nuts lightly with a hammer, the pb blaster may have a better chance of getting into the nooks and crannies.
Good luck!
Boston
Seconding heat. Heat+vice-grip or a bolt extractor. It was the only thing that got mine off.
