Some Trouble With My New Bought Fiesta ST
China
Hello guys,
I am a new fiesta st owner from china, nice to meet you
I have a question about my car's Automotive Instrumentation, Before I purchased this vehicle, I had already had the vehicle inspected by a professional in advance and confirmed that the vehicle's had traveled 92,546 kilometers, but after I received the vehicle and had the ECU read, the mileage display in the gauge magically jumped to 149,000 kilometers, and I'm wondering if this means that there is something fishy with my mileage or if there is something wrong with the gauge that is causing such a problems appear? pls help! I really need a real answer,thank you!
sczamun
U.S. Air Force Veteran
Indianapolis
One thing I notice is that if you multiply 92,454 by 1.6, this gets you approximately the difference. This is the conversion from miles to kilometers.
sczamun
Indianapolis
I would get the distance traveled from the ECU and see how it compares to what the odometer is putting out. It might just be a glitchy gauge cluster versus something fishy going on. I would then try to clean the negative terminal on the battery and verify the grounds are in good condition. Leave the battery disconnected for the night.
I removed the symposer in my car and the A/C just stopped working. I even unplugged the battery and it didn't work. I flashed my ECU with a Cobb Accessport and it magically came back. I think these cars are sensitive electronically.
X
China
thank's for help ,but the mileage display in the gauge is KM as well
X
China
yes,maybe i can try to leave the battery disconnected like you, and what is the Cobb Accessport ,can you tell me more about that? thank's a lot!
sczamun
Indianapolis
Cobb Accessport is a tool used for flashing tunes to the ECU. I am not sure why it worked for me and I don't know if that's the direction you should go.
I would read the distance traveled from the ECU using a scanner tool and compare to the odometer first. Then check your grounds and negative battery connection, and leave it disconnected for a while.
sczamun
Indianapolis
It's just a potential clue to what might be the issue. Might be a coincidence, but little stuff like that will point you towards the truth. I've seen weirder faults with electronics for sure.
X
China
i have search the cobb in Google and find that my car maybe not fit the cobb V3
