ST XTA Warning - Part Deux
jeffreylyon
Pittsburgh
For some reason my original thread was closed by the mods. To summarize, the rear passenger side spring included with my ST XTA coilovers broke after less than 3 years and 8000 unsalty miles. I contacted ST and was told that, because I've dared to track-day my car (no mention of such a qualification on the warranty), because the springs, although part of a coilover kit, aren't covered under the coilover warranty, and because they've decided to augment the warranty with a "because I say so" no corrosion clause, the only thing they'd do is cover the shipping on a list price replacement.
I thought about replacing the springs with ST replacements, replacing them with Swift springs, and throwing in the towel and dumping the whole setup. Towel thrown in, ST XTA's off the car, YCW with Swift springs on. Happy me.
I live in Western PA where we do salt the roads. My FiST wears 200 wear tires all the time and doesn't move an inch in the winter. It has never seen an activity salted road. It does see use in early spring where there can be some salt hanging around from the winter but, again, on 200 wear tires, so only on nice days.
I've included some picture of the springs and fronts below. But first, some thoughts about the coilovers as I broke them down. I noticed most of this when I installed them but I thought that I was buying the best of the rest parts so I guessed that they knew better than I. I've taken apart a fair share of coilovers and there were a couple of things that caught my attention:
  • Plastic lower perches. Instead of the aluminum lower perches that I'm used to, there are plastic, all the way to the threads. They are cast on a thin steel core, but everything that touches a spring or the threaded body is plastic.
  • Set screw instead of locking ring. After you set preload you're supposed to set the ring with a set screw into the body rather than backing up the bottom of the perch with a locking ring. No likey.
  • Crappy finish on the body. It looks like they've been anodized but they're steel so I don't know what the coating is (zinc plating, they claim). At any rate, it did not hold up. In fact, it adds a rough finish that really hangs onto the road grime. It took a ridiculous amount of PB Blaster to clean up the threaded portion of the body.
  • Meh hardware. Like I said, I've been through a bunch of coilovers. These felt cheap. The top nut was too tall. Too much plastic in the spring stack (they have helpers). The uniball was super stiff. The hats feel cheap.
  • Decent dampeners. Other than not having a ride-height adjustment (you have to play with the spring pre-load), the dampeners feel fine. I believe that these are the same as they use on the 1-way adjustable KW coilovers but the KW's get a better coating. The threaded top of the dampener itself seems to bottom on the body to there's a lovely grime and grease catch rather than a smooth transition; you can see that on the right edge of one of the photos. The welds are nice.
In summary: When I bought these I wasn't ready to shell out for the KW's and didn't want to mess around with building my own. I think that I paid $1200 and they are going for ~ $1400 on Amazon today. With the BC Racing and entry-level YCWs coming with Swift springs for less no way should anyone consider these now unless you have to have progressive springs (in the rear). If you live someplace that never sees salt they will probably do fine (understanding that the bodies really hold onto grime and should be broken down for cleaning periodically). If there is ever any salt on the road after winter that could, possibly, end up on the springs ever, even in the smallest amount, they are gonna go.
I just installed a set of YCW Reference coilovers and the quality is miles better. The YCW entry-level coilovers are cheaper and better than the ST XTA's (but I think that they aren't adjustable).
These are getting cleaned up, wire wheeled, painted with etching primer, loaded with Swift springs and aluminum hardware, and put onto my son's FiST..., with a wary eye.
Broken coil (left):
Coating flaking and rust coming through:
Failing finish on body:
maestromaestro
Houston
The name of the game for hardened/high-strengh material is environmentally assisted cracking. By that I mean that if "enough" hydrogen enters the metal matrix, it will likely crack. (Similar issue is with the high strength bolt steel). So, having a good performing coating is essential - if it flaked/spalled off, there's likely going to be a brittle failure of the coils. Salt exacerbates these conditions.
J
jeffreylyon
Pittsburgh
Take a look and the center photo of the springs, the next to last coil from the bottom. The coating has not flaked off and is still well attached (tactilely), but the rust is working through the coating.
maestromaestro
Houston
Ditto for a porous coating or coating with holidays. Corrosion products have higher volume than the metal that produced them, so they exert a force on the coating and cause spalling. Bottom line is that the coating needs to perform its function of a physical barrier.
If the manufacturer puts a shitty coating on a HS material, it may actually cause more problems because then corrosion is not uniform but localized.
