U210B-00 Code
Caguas
Hi all:
I installed the Boomba shifter bushings inside the car. After finishing and starting the car to move it I got the wrench, SRS and traction control lights. The scanner gave me code U210B-00 (Lost Communication with Fuel Pump Control Module (FPCM) ).
I verified the conectors on the trans tunnel but they were connected. My FiST is a 2017 model.
Any suggestions?
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The Fuel Pump Control Module in under the driver's seat next to the consol..
There is also the connector for that module there.
Maybe you unknowingly disturbed the connection to the module.
I
Caguas
Thanks! I will check today after work.
I
Caguas
I checked the connections and everything is connected and the cables look good. To the dealer then.... :confused:
