Ultimate lightweight 17x8 setup
Minnesota
I’ve started looking. If anyone has any bright ideas 💡 feel free to post.
MRX330
Minnesota
No 4x100 on my car but that is the weight I desire. Thank you Jeffrey 🥰
jeffreylyon
Pittsburgh
I looked long and hard and couldn’t find anything within a couple of pounds of the 6UL in 4x108.
MRX330
Minnesota
Btw to go 4x100 is it redrillng or can 4x100 be swapped out?
jeffreylyon
Pittsburgh
Gotta drill. You can press the studs in and out between 100 and 108 (easy) if you want to swap for winter tires or just get another set of 4x100 wheels as they’re pretty cheap and plentiful in the aftermarket. There are adaptors but you’ll lose most of the weight savings with a 3/4” hunk of aluminum and twice the studs.
I did a write up a couple of years ago. Search 4x100 conversion, I think.
The other advantage with the 6ULs are that they are designed to clear really big calipers. I probably have close to .75” between the spokes and my Wilwoods which barely cleared my stock wheels
MRX330
Minnesota
Thread Starter #13
I’m changing out wheel bearings at some point and may see if Mitch can do this at the same time. Switching to winter wheels is going to suck
MRX330
Minnesota
Thread Starter #14
Btw if anyone is going to drill their rotors for 4x100 buy a CARBIDE drill!!! Find an industrial supply warehouse like MSC or Grainger
MRX330
Minnesota
Thread Starter #15
I may not do this and just have Forgeline make me some wheels. Anyone have an extra 5 grand lying around?
