Undeboosted.
Hey guys just got my 2016 fiesta st not too long ago and the car is now throwing a underboost code (p0299) and is running absolutely awfully so immediately I checked my charge pipes and there wasn’t any popped. And then I decided to start checking vacuum lines and couldn’t find anything there either. Cleaned my throttle body and MAF and nothing as well. The car does have an aftermarket turbo and downpipe and exhaust. My next guesses would be boost control solenoid or a boost control sensor. And no the car is not blowing any kind of smoke and there isn’t any oil in the intake system or any oil coming out of the exhaust. Could use a little help here considering I’m new to the community. I also attempted to check the wastegate to see if the rod coming out of it could and would open and it would but that still doesn’t mean it couldn’t be messed up right ? Just want my car running good again it was so much fun while it ran right . Any suggestions or help will mean the absolute world. Thanks
Before you dig into all that, I'd say it's worth double-checking all your boost hoses again. Not just visual checks, double clamp and tighten everything just to rule it out before you go dropping real money chasing a fix.
Hotside boost hose on the passenger side*
FiestaSTdude
Welcome to the forum!
I would definitely double check the boost hoses like @FJ16 suggested. I've also heard that a cracked intercooler could create a boost leak, so I would look at that as well.
T
Okay thanks guys I’ll check it all over again. Could it be possible too I have a leak in my intake ? I also read that could be a possibility but I don’t know how true that is I’m sorry for all the questions but I’m just new to boosted cars in general.
T
and thank you @FiestaSTdude for welcoming me to the forum! And thank all you guys for the help! I’m gonna rip back into the car today so I’ll let you guys know how it goes
FiestaSTdude
I think that an intake leak could cause that, but I've never heard of that being an issue before.
T
Checked the car out all last night and pulled down every charge pipe and checked the intercooler for cracks and nothing. Then really checked over the charge pipes well. Got new and a little bit wider hose clamps and tightened them all down really well cleared the codes and took the car for a ride and still nothing. Still feels like the car is just running on all motor in all honesty
FiestaSTdude
https://www.autocodes.com/p0299_ford.html
Check out this link and start looking into the different things they say to fix it. Maybe start with the cheapest/easiest fix. None of what they said jumped out as something I've heard of before.
Do you have any other codes?
Boost control solenoid for sure should be checked. Do you have a boost leak tester and an air compressor? The only way I’ve been able to locate boost leaks is to charge the whole system up to 15-20 psi and spray soapy water on every connection. Could be the BPV as well.
A leak before the turbo can’t cause boost problems. Exhaust leak preventing all of the exhaust from being routed to the turbo could. A boost leak could. Could also be a blown turbo or a wastegate actuator that’s gone kaput and is opening at like 2 psi or something incredibly low. That’s way less likely than a boost leak, however.
T
Thread Starter #13
For anyone wondering that decides to look at this thread to figure out their issues with their car I finally found the problem the stock dv took a dirt nap all it needed was a go fast bits vta+ and now she’s all good to go again!!!
Glad you got it sorted and thanks for updating the post. How do you like the sound of the GFB?
T
Thread Starter #15
I love it it’s fantastic if you like loud and abnoxious 😂 you barely hit the throttle and it whooshes so loud 🫡😂
