Fooling around with datalogs today, I wondered if I could calculate how much top end gained by tuning and HP mods since I was stock.
Started with an old log with OEM IC (already had Mountune intake) with top end recorded two ways, average 138.5 mph calculated on max rpm times gear ratios.
VDyno 3rd gear run (smoothing 5) around same time showed 161 HP.
Found Cd of 0.33, CdA of 7.57 in Wiki Ecomodding
Picked relevant easy formulas from here: http://craig.backfire.ca/pages/autos/drag. Ran calcs and concluded either I have 133 HP at drag-limited speed of 138.5 mph and VDyno is less accurate than I thought; or CdA is wrong in Wiki.
I checked Wiki again and found their assumed 0.84 reduction factor used for calculating CdA was not appropriate for this calculation. Using Cd 0.33 with A=27.3 sf, at 138.5 mph, HP calculated to 158, very close to the VDyno # of 161 HP.
With current Cobb S3 tune, 2J DP and recent logs, VDyno says 181 HP, and top end now calculates to 144.8 MPH. Sounds right to me. Butt dyno says I am at least 5 mph faster.
Just wanted to share some calculation fun, and lend some backhand credibility to VDyno. Data and analytic tools are wonderful these days.
