I have recently gone another route with my Fiesta and will no longer need the following parts which I never installed. All items are new not used. Priced to sell quick.
Paypal or Bitcoin accepted. Goods and services for paypal but buyer pays fees.
Buyer pays shipping and I can provide a quote. All items ship from zip code 55110
Spec Stage 3 clutch and lightweight aluminum flywheel - $750
The Spec Stage 3 clutch kit for the Fiesta ST is built in the aggressive form of a 6 puck, segmented clutch disc utilizing Spec's carbon semi-metallic pad material. This kit has a high level of torque capacity and can handle many aggressive driving situations because of its quick and solid engagement characterstics. The hub is still sprung to aid in harshness reduction.
Torque Rating: Supports up to 352 lb. ft.
Manufactured from only the highest quality steel and aluminum, they are the only flywheels on the market manufactured to a .001 machine tolerance, guaranteeing a flat seating surface for the clutch and smooth rotational qualities for perfect balance and extended engine life.
Misimoto Oil cooler- Black with thermostatic sandwich plate - $500
Mishimoto engineers started with a large 19-row oil cooler and mounted it in the front of the vehicle where it receives the most airflow. The oil cooler was designed to bypass the stock liquid to liquid oil cooler in order to get the best possible oil temperature reduction. A new CNC center bolt and aluminum coolant bypass tube are provided to easily eliminate the stock oil cooler unit. Application specific braided stainless steel lines transfer oil from the cooler to the engine and feature -10AN fittings for an easy installation. Mishimoto engineers saw consistent temperature decreases of over 35°F (19.5°C) using our non-thermostatic sandwich plate. Proving that this oil cooler kit can withstand the stresses of the most extreme applications
Toyo Proxes R888R in 205/40-17 - Set of 4 - $500
Evolving from the Proxes R888, the Proxes R888R is Toyo's Racetrack & Autocross Only tire for driving enthusiasts participating in track days, road racing and high performance driver education events. Like all Racetrack & Autocross Only tires, Proxes R888R radials are not intended to be driven in near-freezing temperatures, through snow or on ice. It's also essential these tires be stored indoors at temperatures maintained above 15 degrees F.
Proxes R888R tires feature an R-compound tread that quickly reaches operating temperature and provides high grip levels for maximum cornering traction. The tread compound is molded into an aggressive, asymmetric tread pattern with massive outboard shoulder blocks to provide the lateral grip needed when driving on the track. Continual development of the contact patch gives the Proxes R888R greater levels of dry traction for improved braking, acceleration and cornering versus its predecessor.
While Proxes R888R radials meet D.O.T. requirements, they are not recommended for driving in wet conditions when shaved or worn where standing water is present and there is a risk of hydroplaning. Drivers should drive cautiously at reduced speeds if they encounter these conditions.
Internal construction of the R888R features a two- or three-ply (depending on size) Rayon casing supporting two wide, high-tensile steel belts. A spirally-wound nylon reinforcement ply provides additional high-speed stability and durability.
Focal F05 Wheels - Set of 4 - $300
Offset: 42mm
Backspacing: 5.944"
Bolt Pattern: 4-108
Rec. Tire Size: 205/40-17
Weight: 20.0 lbs.
Finish: Flat Black Painted
Construction: 1pc. Gravity Cast
Offset: 42mm
Backspacing: 5.944"
Bolt Pattern: 4-108
Weight: 20.0 lbs.
