Wiring Analog P3 Gauge
NomansFist
Seattle, WA, USA
Hello, i'm attempting to wire an analog boost gauge for my 2019 FIST, the guide from P3 is a generic one and not working to power the gauge. Can someone help a newb with where the power line should be that there'd be a suitable constant 12V power source?
TIA
Noman
Galax, VA, USA
I used a fuse tap to wire in my gauge because I didn’t want to cut any wires. I used the engine bay fuse box because my gauge had a wire to dim the gauge when the lights turn on. I used the fog light fuse for that.
If you don’t have anything like that it’s probably easier to use the fuse box behind the glove box and just run a wire to the drivers side. Right now I can’t remember exactly which fuse is constant but do you have a multimeter? It’s pretty easy to find.
