Would 225/45/16 tires with 16x8 +38 wheels fit.
ronmcdon
Curious about this. Really liking this size from Dunlop Z3 that I haven't noticed before. Note I'm currently using a set of 205/50/16 and overall diameter is 24.2. 225/45/16 has less overall diameter at 23.9. I'm dropped maybe half an inch with coilovers.
any input would be most appreciated as looking to replace my tires in May or so.
https://www.tirerack.com/tires/tire...sidewall=Blackwall&partnum=245WR6Z3&tab=Sizes
they have an 8.9 section width with a 7.9 tread width. If you are only dropped a half inch on your coils and your overall diameter is 23.9 you could probably run them. The main thing I would be looking at is rubbing over bumps ..
What is crazy is my 215/40 17 Falken RT 660‘s have exactly 1/10 shorter overall diameter at 23.8 and my section width is at 8.7 and my tread width is 7.9 :LOL:
Yes the Falkens Run wide. So I can tell you that at a 1/2 lowered which is not as lowered as my car you should be fine.
edit ... you would probably want to trim your fender tabs up front.
