X49rs
just installed a new x49rs, Loaded up base map tune, car stalls out on startup, very rough idle, So I loaded back the 93 Tune for the stock turbo, car idles fine. If needed could I drive car on old tune and just not go WOT. Need the car for the day and tuner isn’t getting back to me.
Honestly the base map or economy map might be better. But yes stay out of boost.
A
Like stock map? The base map the tuner sent won’t even run the car. It stalls out and runs like crap.
So the stock map will run less timing and boost than the 93map and the economy map is limited boost. But I'm not recommending you drive it the way it is. But if I had to I would try the stock map and keep it out of boost.
daloonie EcoBoost Engine Upgrades 5
