Turbo Blanket for Stock turbo
re-rx7
Ardmore
Ordered a Turbo blanket for my hybrid. I ordered one for a wrx/sti to see if it will work. Will update with how it turns out for anyone interested.
What/how much (if anything) has to be removed from the turbo area in order to get one of these on properly?
(I know they have those wire connectors, and are split, but everything is so restricted around our snail, I am hesitant to get one.)
I was thinking about one for the factory setup.
re-rx7
re-rx7
Ardmore
What/how much (if anything) has to be removed from the turbo area in order to get one of these on?
Im not running my heatshield so it was in need of something. I think the factory heat shield is more than adequate. I just couldnt get mine back on due to me cutting it up to get it off.
OK, but I was going to run it WITH the heat shield, as a way of keeping the heat (and therefore helping the flow) INSIDE the turbo, and NOT as a shield for the surrounding areas/firewall/etc. ;)
re-rx7
re-rx7
Ardmore
Thats a gd thought. The more heat in the better. Im curious to see how it affects spool.
