Where to source Triple R Front Splitter
YIN
Just a few minutes ago I finished installing a second.
It fits 100% perfectly.
Dave
No trimming for the underside or bumper? Just drilling then put on ?
Yes, that's about it.
This last one I just put on, I found out that they drilled two holes differently but that is no problem.
I came up with an easer way to install it that requires NO cutting or trimming of anything.
Remove the two outboard bottom 7mm screws that hold the black fender trim on.
Tuck the trim piece just above the bumper cover instead of on the bottom and reinstall the screw.
Then you need to drill holes into the bumper cover through the 6 main mounting holes (3 on each side) already provided on the splitter.
Next use plastic expanding nut inserts (like used for license plates) with the correct style screws and fender washers.
Dave
Young L
anyone know if the sideskirt or rear diffuser fit the US spec. I emailed them but havent gotten a reply.
I just emailed them yesterday, they said the side skirts should fit fine as far as they know but that there could be some differences between them, might help to get a nice underside picture of a Euro skirt to compare (giggity).
Also they mentioned the scissor jack may not work with these installed, but a trolley Jack will work.
I'm definitely thinking about getting some, not tooooo bad shipped to the US but I wish someone stateside sold them. Quoted ?65 for shipping.
