what tune to use?? mixed and matched parts
caliboy15
here's the parts that I acquired
Cobb AP V3
Cobb DP
FSwerks Exhaust
Mountune Induction Kit
sorry for my ignorance, this is my first turbo car and I'm still learning. In about a month or 2 Im going to purchase Intercooler from Cobb or Mountune
but for now, what tune should I be running? stage 2?
Thanks in advance!
With out the larger IC you "could" run stage 2 but you may notice timing issues. stage 1 will be the safe choice or a protune (if you plan on getting on after the IC dont bother unless its a feww update).
Yeah like bob said, an IC should've come first (before the DP and exhaust) and you're right at Stage 2's requirements. I'd run stage 1 to be safe. Get the RMM as well.
Just use Cobb's Map notes as a guide.
At least the IC is all you need now to go straight to Stage 3. I personally wouldn't get a custom tune until I finish buying everything.
C
caliboy15
I want to do protune once I get my IC so I guess Ill be running stage 1 for now
with the bigger IC and charge pipe I guess that will be stage 3
C
caliboy15
that's the plan but I got these parts with a price I couldn't pass
RMM is going to be installed tomorrow
