- Member ID
- #2134
- Messages
- 4,097
- Likes
- 948
Based on what mountune suggests, this tune will add a TON of torque -- especially in the mid-range. The HP also appears to come on earlier and hold up longer (nearly to redline). That's going to be noticeable at the track in 3rd and 4th gear. Third is the primary corner exit gear (where the torque will come in to play) and 4th is where the car gets to stretch out a little on a longer straight (HP will come in to play there). I was short shifting a little bit in the MP215 tune to sustain TQ, we'll see if I need to do that now.
Around town, I don't really notice much difference. It's very civil. It does go like the devil when asked to accelerate in third. I'm sure I've shocked a few folks that were thinking, "don't do it...don't do it" as I made a right turn merge in front of them onto a nearby arterial that has some runway to allow me to air it out a bit. Realistically, I can really only air out 2nd gear in this setting. By the time I'm into third at all, I'm easily over 60 (speed limit is 45 on that stretch...it is wide open with no cars *normally* turning, entering, or exiting in front of me as I accelerate, but is a bit of a speed trap as well).
This is not a car I drive much, so it's going to be difficult to really assess any difference until I'm out on a closed-circuit road course. That won't happen until late spring soonest.
Having said that, it is quite sporty with the MR230 setup and I am very happy with the adjustment. It is a little louder in the 3300 RPM range under WOT with the high-flow cat, but I have not really noticed any drone with the mountune cat/Borla combination. Second gear WOT exhaust sounds are very nice; I have not had a chance to air it out third yet, but I suspect that will be very pleasant as well.
Aside: Considering a couple of cosmetic bits, too. :blushes:
![Shhh! [shhh] [shhh]](/images/smilies/shhh.gif)
