As the title says, I found some oil on my spark plugs. Not on the electrodes, but in the well. Explains why I have random negative corrections. Has anyone had to replace their valve cover gasket?
It would in theory, but I just don't see it being a possibility as you would probably have to be losing a lot of oil that way. Most of the time when people have oil there they find their plugs to be perfectly normal when removed.
I would probably just keep an eye on it personally, under the assumption that it's not completely flooded with oil. The Mk3 Focus had the same issue on a bunch of cars and people would go have it replaced under warranty just to have the issue resurface, so it mostly just became tail-chasing. I had the issue with mine but it was negligible so I just cleaned it more often.
