FearTheSnail's ST
FearTheSnail
Thread Starter #128
Apparently I never posted these here:
[video=youtube;7h2KeiF8c10]https://www.youtube.com/watch?v=7h2KeiF8c10[/video]
[video=youtube;uIdTNQ-Cqvs]https://www.youtube.com/watch?v=uIdTNQ-Cqvs[/video]
shouldbeasy
This car still tearing up the street?? I saw your add in the 'for sale' section and it has be scared!!!
FearTheSnail
Thread Starter #131
Yep. Drove this car to work this morning. The items listed in the for sale section were from my wife's car.
FearTheSnail
Thread Starter #133
As of a couple weeks ago I will be replacing the engine. I picked up a pretty much new engine from a nearby scrap yard with 2,500 miles on it. My current block has a spark plug in cylinder 4 that will not come out. I am afraid that if I try any harder that I will shear the plug off in the block.
During this process I will be replacing the still stock clutch & flywheel. I have moved to Montana and no longer have access to e85 so I am no longer able to use the GTX2867r to anywhere near what it is capable of. I will be picking up a Garrett Gen 2 GTX2860r with a .52 AR Tial exhaust housing to go to a smaller faster spooling turbo. I have been pondering on the idea of meth, but have not placed an order on anything to do that yet.
How long/how many miles has that plug been in the head??
When I hear stuff like this, it makes me want to change out the 1 year old/6K mile factory plugs IMMEDIATELY, to prevent this from happening. [:(]
FearTheSnail
Thread Starter #135
I don't think this is a very common issue. I could be wrong. The plugs had about 5k miles on them. I try to change them every other oil change. DHM had always recommended to replace them every oil change for protective measure. I used anti-seize every time I change plugs as well.
These went in at around 60,000 miles. The car now has ~65,000 miles.
In all my years I don't think I've ever seen a manufacturer say to use anti-seize....after all ...When they designed the engine they most likely factored that in or thought about it and decided against it...IMO.
FearTheSnail
Thread Starter #137
I'm not saying its the right way or anything, just was making sure to note that in case it was of importance. Interestingly enough my brother who is a mechanic, the first thing he asks me, did you use anti-seize on the plug?
FearTheSnail
Thread Starter #140
Well I did a thing. I ordered a smaller turbo. Not much smaller, but it should be a good change from what is on there.
Current Turbo: GTX2867r with if I remember correct .64ar Tial Exhaust Housing
New Turbo: Gen 2 GTX2860r with .52ar Tial Exhaust Housing
https://www.atpturbo.com/mm5/mercha...oduct_Code=GRT-TBO-754&Category_Code=GG2-2860
I need to figure out what I am going to do for fueling. When I was in Idaho I had access to e85 and would mix it for an e50 mix. Unfortunately e85 is not available where I am at here in Montana. I could order e98 by the barrel or I could find another fueling solution.
