FSWERKS CBE owners?
Planning to order the FSWERKS CBE and I want to hear from anyone who has this CBE. I love the sound and the quality looks great. Anyone have any issues or concerns with this CBE? Any rubbing or issues with tip placement?
caliboy15
[video]https://youtu.be/s36qcFSFiPo[/video]
No issues whatsoever! Absolutely love it
M
Sounds great. Thanks for the link. Did you use the stock hangers or Cobb poly hangers?
M
Awesome. Thanks for your help and feedback. Placing the order today.
My FSWERKS tips are about 1/2" from the bumper, but no problems. Fitment is good, spray your stock catback bolts with WD40 the day before and during removal. Only loud when you're on the throttle hard, otherwise just a good rumble. I used the stock hangers and don't have any issues yet after a couple thousand miles. Would definitely recommend.
M
That's the info I wanted. Thanks guys for the info. Looking forward to the install.
Love it. Install is super easy. And, it would be super easy to make it into a straight-pipe setup should you ever need that kind of flow.
Don't mean to hijack, but does this catback match up perfectly to the Cobb downpipe? Or is some modification required? I noticed that in your sig [MENTION=1971]caliboy15[/MENTION]
M
Installed the fswerks cbe today. Sounds great. No issues using the stock hangers. Pipe clearance was tight near the s pipe heat shield but no issues. Got a slight rub near the heat shield but bent it out of the way. Might install cobb hangers but not in a hurry. Looks great. Nice product FSWERKS! !!
Young L
still on the stock dp? If so any drone in the the 3-4k rpm range when just cruising, would be around 80mph.
M
Still running stock dp. No drone while crusing. Haven't taken it on the freeway yet. Got up to 65 and had 0 drone.
