On Thu, Jan 21, 2016 at 11:02 PM, David Li <lidavid87@gmail.com> wrote:
Hi Tony,
That's not what you said previously. Please see what you wrote earlier:
On Sat, Jan 16, 2016 at 7:39 AM, <Sales@pumaspeed.co.uk> wrote:
There are no invasive processes to cause this
If he ecu was programmed with bad info the car would simply not start
If the ecu ws programed correctly but had a very poor mapping the would start and run but power would be affected.
Can I 100% guarantee the car will never do this again ??? 100% no, but no one else has ever reported a bad experience like this
Regards
Tony McQuire
The issue I had was EXACTLY what you described.
I don't want to drag this longer as much as you do, but as a customer here that just had 3 months of downtime with no guarantee or fall back that it might happen again. You are not exactly giving your customer much confidence.
There is a first time for everything, so even if you have never experienced issues with other cars does not mean your reflash did not cause this. If you are so confident that it was not the reflash, then you should be offering a peace of mind for the customer just to back your products and your words up.
Looking forward to a more promising response from you.
Best Regards,
David
On Thu, Jan 21, 2016 at 7:04 PM, <Sales@pumaspeed.co.uk> wrote:
We have never had any issues, ever
The ecu on the st180 cannot be made faulty by a tune file being introduced to 256k of the 2mb
If the file is wrong the car will instantly not run.
So the answer is no
Regards
Tony McQuire
A & K McQuire Ltd (T/A Pumaspeed)
178 Batley Road
Alverthorpe
Wakefield WF2 0AJ
Pumaspeed.co.uk
Milltekexhaust.Pumaspeed.co.uk +44 (0)1924 360002
Sent: 20 January 2016 03:01
To:
Subject: Re: Tuning files for Stage 1 and Stage 1+
Hi Tony,
I can see that you are confident in your tunes. But the risk is high for me and I would like to reduce the risk of remainder of my warranty being void and having to foot the repair costs myself.
So therefore, I would like to ask what you are willing to compensate if I flash your tune again and the ECU becomes faulty again?
On Wed, Jan 20, 2016 at 4:32 AM, <Sales@pumaspeed.co.uk> wrote:
Im sorry we are not at liberty to give these details, he does not wish for end user contact, he does not have the time
I can pass on any email you wish.
His files are static and have not been updated or changed he has used them many times and no errors have been reported
Regards
Tony McQuire
178 Batley Road
Alverthorpe
Wakefield WF2 0AJ
Pumaspeed.co.uk
Sent: 19 January 2016 08:34
To:
Hi Tony,
Can you give me the contact details of your tuner?
On Mon, Jan 18, 2016 at 8:33 AM, <Sales@pumaspeed.co.uk> wrote:
Sorry David but the device is used. Also we have never seen this issue before so I believe that the unit and mapping not be at fault.
The ECU as I have mentioned earlier must have been compromised directly from the factory…
Regards
Tony McQuire
