Tim's Molten Orange TURBOST (pic heavy?)
DHM1
Royal Oak
#42
So I figured I'd make a little post about my experience with [MENTION=1098]DHM[/MENTION]. I won't sugar coat, but I'll say that even though it wasn't a perfect experience I am more than happy in the end.
I decided to buy my IC at possibly the worst time. Due to a perfect storm of circumstances, things took a little longer than I'd like. But that's the price you pay when you're buying parts from a tiny little company that's active in the community. Russ was on vacation when I originally ordered, and then went to Florida for a few days to help out with Erik's car. Can't rush perfection, I guess. I'm happy I waited it out.
When I first approached Russ, I asked about getting a custom color and having a BOV flange added onto the IC. Russ worked the BOV into the deal and the price was extremely fair. Originally, I wanted just the crash bar custom colored. Then Russ informed me that he could take apart the BOV for me and have it powder coated along with the crash bar. He could have easily saved himself some work and neglected to tell me that this was an option, but he looked out for me! Russ also answered any stupid questions I had while I waited for my parts to arrive, which ranged from vacuum line sizing to "oh, shit, the BOV blockoff I ordered won't work what do I do?" lol
Sooooo I finally got the parts.
Holy packaging batman. I think they were the most well packaged parts I've ever received. It took me a solid 10 min to unwrap all of the plastic, lol. I don't need to tell you how awesome the quality of the parts is, either. Welds are pretty, powdercoat looks good (although I'm not as in love with the color as I wish I was) and everything is blemish free.
I'll definitely be buying from DHM again, this was my test run... and like I said... things weren't perfect but the product was delivered as described. Just a little slow. Next stop, Quickspool.
Build time is Deff our biggest weakness. We try and make the customer support the best we can and deliver a supreme performing and quality product. Thank you! Be sure to copy and paste this for a FB and or in my forum review page. Thanks!!!
Plus don't for get install pics I think that color will be epic on your car. Also some logs so I can share!
Russ
twolf
twolf
Canton
Thread Starter #43
This turned out REALLY well!
twolf
twolf
Canton
Thread Starter #46
Alriiiiight so, finally got some time to install parts!
The original plan was to head over to my friend's house, and use his garage and tools and have fun installing my FMIC/BOV. I decided I'd wake up early in the AM and throw my springs on the car, so I ran down to AutoZone to pick up a spring compressor at 8:30am, decided to grab a 3 arm puller to make pulling the wiper arms easier.
I'd recommend removing the cowl to do springs. It's really only like 5-10 min of work, and makes things a lot easier. If you do this you don't need to remove the bolts for the brake fluid res, or struggle to reach the rear top hat bolts. Win-win.
Here you can see the puller on the wiper arm (with the nut still on the shaft, lol, brain fart) getting ready to get to work.
The front springs probably took me like 30 min each, but I was chatting with my GF and taking it slow, so I could have probably done it faster. Very simple, remove the nut from the sway bar end link (you'll need either a pass through driver or a box end/ratcheting wrench and an allen key), remove the two bolts/nuts attaching the strut to the knuckle, undo the bracket holding the brake line to the strut, pull the clip that holds the wheel speed sensor wire off of the strut, and that's it. If I recall correctly.
From that point, simply remove the 3 13mm nuts holding the strut into the strut tower. I had my GF hold the strut up while I did so. Compress the old spring, remove the top hat, put the new spring on... I didn't need to compress, I simply pushed the top hat on and had my GF thread the nut on.
The rear springs were stupid simple, it's literally 1 bolt. Remove bolt, push down on the axle, pull spring out. I had my GF stand on the wheel while I pulled the spring out. If I did it again, I wouldn't even bother removing the wheels.
Excuse my filthy wheels but:
The handling is significantly different, but ride quality didn't seem to suffer. My GF thought ride quality was actually better, she loves the springs! Swift FTW.
Then I washed the car, I was kinda killing time waiting for my friend to get home so we could install my FMIC.
My keeper of a GF sat inside the car vacuuming/wiping down the entire interior while I washed the outside. The efforts were futile, the car was just getting dirty as quickly as I cleaned it.
It started to get late, and my friend still hadn't made it home, so I phoned in another friend and while I was waiting for him to get there I took the bumper off and removed the stock FMIC. Very simple, probably took 30 min total.
Then, since the DHM IC/Crash bar don't have instructions, we decided to go get the IC from inside and look at them and decide what needed to be done next.
Size comparison:
I wish I took more pics, but it was getting dark REAL fast. By the time I took this pic, it was 7:38. Sunset was at 8.
Installation is pretty simple. Just exercise a little common sense. You want to go all over the stock crash bar and remove EVERYTHING that is attached to it. You'll want to first support the radiator assembly because it is held up by the crash bar. Pictured here... hold my beer:
You know what they say... if it looks stupid but it works, it ain't stupid.
The intercooler bolts on in two places: up top and down low. The bolts on top go through the intercooler brackets, through the crash bar, and into the radiator support.
On bottom, it bolts into the radiator support in the same location as the stock IC does (I believe, it may actually be where the stock IC brackets bolt in. I'm not sure, because I removed the stock stuff so quickly and didn't pay attention. Either way, you'll see. It's not difficult. Common sense.)
In the pic above, you'll see me under the car trying to remove the bolts from the Turbosmart BOV. I don't remember how I installed the thing, but it was so difficult to un-install. Probably because I didn't have the proper extensions/u joints. By the time I was done removing those 3 bolts, it was dark....
My friend and I took the bumper inside and started removing the honeycomb. This was a bitch, everyone understates it. :p Maybe our technique was bad, but it took a good 20 min to get it all un-clipped.
Then I hurried up and put the bumper back on and the car back together.
By the time I picked all the tools up, went out and grabbed some dinner, etc, it was midnight. GF and I went to sleep, woke up at 4am, and made the trek to Caffeine and Octane to meet up with the ST Club.
Snapped this pic when I was on the way home tonight. I've been running 93 octane exclusively because I was unsure of when I'd be going down to get dyno tuned and didn't want to get "caught with my pants down" so to speak and have e85 in the tank.
Also did a data log just to look at charge temps:
jeff
Evans
#48
Nice thread wolf and congrats on a nice batch of new mods. I put swifts on my Scooby a few years ago, A+.
J2FoRS
Central
#49
You're going to run no grill all together? Good write up, been debating my route.
twolf
twolf
Canton
Thread Starter #51
No, I'll be putting the grille back in. I just need to sand it down.
Looking good Tim! Maybe my Mountune springs will work out as well as those Swifts.
Let me know when you want to do them.
twolf
twolf
Canton
Thread Starter #53
The JST Performance Shop Dog:
Strapped Down:
228whp, 330wtq.
jeff
Evans
#54
That is terrific, congrats, great numbers.
Chicago
#56
So on the same dyno you went from 202hp/266 tq to 228hp/330tq with changes being catless dp, DHM ic, and E30 custom tune?
J2FoRS
Central
#57
Nice dyno vid. Don't think shop dog likes the exhaust note. Haha
