- Member ID
- #2416
- Messages
- 1,008
- Likes
- 381
A couple of weeks ago I finished putting on new bits on my FiST - that included a full brake upgrade (calipers, rotors, pads, and in case of the rears - hubs, because I also converted to the 4x100 bolting pattern) using Wilwood parts.
However, the new setup resulted in a considerable brake drag; by my estimates, I have lost quite a bit of MPGs (from 33 to about 28 mpg on average) and about 10 mph for the same RPMs. I also see higher than expected temperatures of the rotors even after driving long distance at cruise speeds and not using brakes for stopping (at the end of the trip, I used engine braking). Granted, I went from 17" to 16" inch rims, but the overall change in tire diameter is next to nothing and I confirmed the speedo accuracy using a GPS app. The tires are also different, so there is some (potential) change in rolling resistance, but it is a second order effect, in my opinion.
So, despite the above, I still need to get the data on speed vs. rpm (at 60 and 70 mph in 6th gear) so that I can compare the "before" to what I have now. Currently, it is about 2600 rpm @ 70 mph (6th gear) and about 2100 rpm @ 60 mph (6th gear).
If you own a stock FiST, would you please post what you see on your tach at 60 and 70 mph in 6th gear?
Much appreciated!
Much appreciated!
