The merits of stopping at a stage 2+ setup
Thanks! :)
I really do feel like there's a lot of stuff that people buy expecting it to do more than it actually ends up doing. I'm a "bang for your buck" type shopper. It takes me ages to buy anything because it goes through an exceptionally long research process with me until I absolutely feel that I will be getting my money worth on what I buy. Then I put it in the cart and wait 48 hours. If I still want it, it gets bought. Not including the tires and shift kit mods I have spent approximately $1025 and I am putting down stage 3 performance numbers. I think that says a lot about what just good gas and a good tune can do for you.
jeff
jeff
Thread Starter #202
Thanks! :)
Thanks for this and the previous post with the vdyno graphs.
Yes as I've said I agree the Strat tune is fantastic.
I might have missed something but are you currently on the Stratified tune still or something else?
The one place I feel differently is what you said about no significant bump in power/torque once the FMIC is upgraded. For me that upgrade was as significant as the change from stock to Strat flash tune stage 1 as they say, and now with a custom tune even more so.
Great curves on your vdynos there!
FistSt215
I should do a log to see where I'm at stage 1 ots . It's been awhile since I've done a Vdyno run. Do you guys usually do a 3rd or 4th gear wot ?
Yes that is a Strat tune and it's my third revision. The FMIC itself doesn't add any power. It makes it a bit easier to add timing and spark by the merit of cooler, denser air entering the engine, however. As I explained before however, I was already rapidly approaching MBT. MBT is the limit at which you can add timing to reach the car's optimum torque production without modifying a major variable such as the turbocharger, which would lower the needed timing you were adding before now that the turbo won't be so maxed out. Since our turbo has nothing left to really give after around 24 psi, the only option is to then add timing and spark. Ford's tables are extremely well-calibrated for this, so it's not like it's going to magically improve and you can only add so much timing before the engine is simply stops making torque due to MBT limitations. Exceeding MBT is a terrible idea for many reasons.
jeff
jeff
Thread Starter #205
Sorry for the confusion. What I meant to communicate was that the FMIC upgrade AND a tune is where I felt alot more power. Not just the FMIC by itself. So you did the Strat custom option or are you continuing to do the +$25 revisions?
twolf
The point is this:
I'm on a custom tune. I have only an intake, exhaust, RMM, and Turbosmart BOV. None of these increase my cars ability to make power.
I have an IC waiting to get installed, and I am going to get dyno tuned.
I won't see a HUGE difference when I get the FMIC installed/dyno tuned, at least compared to going from stock tune to custom tune.
jeff
jeff
Thread Starter #207
The point is this:
Yes I completely understand that.
Install the FMIC yourself and save some money, it is very easy to do.
twolf
I am installing it myself. I install everything myself.
I've read conflicting reports on do I need to upgrade to a turbo smart BOV going to essentially stage 2 CAI/FMIC and a custom tune or will the OEM one do the job.
dyn085
Exactly this. A lot of people seem to get parts and tunes confused when it comes to making power. I bring up often (but it doesn't seem to take on many) the fact that, if a part creates a legitimate measurable increase, it has to do it on the exact same tune. If it can't make gains on the same tune, then it doesn't have gains. If you have to change the tune to see results then you got results from the tune.
According to the CAT timing compensation it looks like there is only 1 degree of timing that's added when dropping CAT from 100 degrees (where Ford establishes their baselines) to 70 degrees.
dyn085
Either one works but third is easier on the drivetrain.
No, you don't need one.
jeff
jeff
Thread Starter #213
Got some logs of my tune revisions on Vdyno, this shows the progress, all on the same road about same temps, I was very careful of that. First time using Vdyno and I'm pretty sure these numbers are way off.....but it is Vdyno.
My first tune had the turbo kicking in late. Version two fixed that. Revision three bumped it up and evened it out more. Still have 95% traction. Tuner is working to see if a fourth version is needed. The car feels great, I'm very happy with this setup!
antarctica24
I have nothing to prove, nor do I have time to link you to all of the discussions that can be found by simply searching and reading the forum. If you want to believe in it then great, believe in it. Like I said, I own one and know for a fact that it does nothing on my FoST, and I've been part of the community long enough to have watched parts get introduced, advertised, then tested to verify/disprove claims. Just don't be surprised when you do a datalog comparison later just to find out I'm right and that you spent that money on eye-candy.
It's definitely the best-looking eye-candy available though, imho.
In my honest experience, I think there is something that is not being considered here. The Focus is a 2.0 liter engine. The Fiesta is a 1.6 liter engine. the focus has a Different turbo than the Fiesta. While the fiesta system is good, more air is more air. Thus your comments about the 2J are correct, but are correct for all bigger intakes. Some may be hotter than others, and the computer obviously corrects for that. The stock computer is not static in its programming. It is dynamic. This computer is capable of handling 5 lbs of boost without any tuning what so ever and correcting the fuel to match it. THIS IS A FACT NOT FICTION. While the tuners may not want you to know that, it is an absolute fact. I would absolutely expect installing a CAI on a Focus to not show as much of a difference versus installing the same intake on a Fiesta because the Fiesta has a smaller engine. Both are restrictive, but the changes that have to be made to get the same results between the two cars is different using the same intake because of more displacement. In other words, on the Fiesta if you used lets say 3 inch plumbing, on a 1.6 liter, you would need a 3.5" or 4" to get the exact same gains because you have more space to fill. I would expect gains on each setup, with the exact same CAI, but more on the fiesta. This is simple science no guessing here. I am certain with enough research on your part you can come to the same conclusion. I am not trying to disparage you, your just wrong.
Anything you do to this engine to make it breathe better, will improve the performance of this engine. Air in, Air out as efficiently as possible without tuning anything and I will prove that as soon as I find a dyno. Now with all of that said, having driven this car for the equivalent of 13 years as the insurance industry says, the average driver drives 12,000 miles a year. I am an expert on how this car felt before any modifications were done and I am telling you that this car is making more power without a tune than it was before anything was upgraded. Now while I may not be an expert on access port yet, I am an expert on HP TUNERS, and know engine management and know what this stock computer can and cannot do own its on. If bolting on a CP-E intake or any other intake for that matter increases horsepower and torque by 1. it is in increase. Is it worth what people are asking? that is for each individual to decide. But even if the computer makes the adjustment on its own because it saw cooler temps, or more air, it made an adjustment to accommodate and thus more power was created.
One last thing, the be completely fair, the conversation needs to include the aspect of price vs performance. if you are not changing the turbo, and keeping the stock turbo, not going with a cyborg, or the likes, I would surmise the stock intake is adequate. As for the Big Mouth intake. Its a cool piece, and I like having it. I am going with a bigger turbo, so being able to get more air in the car for the turbo is a plus.
If you are going with a bigger turbo, or any turbo including the cyborg, then a CAI with the ability to intake more air than the factory would be recommended.
With the CP-E and Big Mouth installed, I have better throttle response, and longer turbo spinup holding ability. I don't know what else to call this effect. When I downshift the RPM is holding out longer, so I am not getting the feeling of the jerkiness where the turbo is having to start from scratch. That all sounds dumb but that is the best way I can explain it. I definitely do not feel like I have to justify anything to anyone, but I do feel it is necessary to report my findings for those who might be interested and to dispel those who are just wrong in their assessment.
Jeff and I are on the same page here as I have said in many other posts. There is something to be said about usable power. making 376 hp on this car is so cool it is dumb crazy. I applaud anyone and everyone that goes there. I would say why not? But that doesn't take away from what Jeff is saying. If I was making 375 in my car, and having to deal with it every day, it would piss me off. The fun in driving this car is being able to fully use all 6 gears pedal to the floor at any given time. That is why I have said that this car, this chassis, something between 250/250 and less than 300/300 is the sweet spot for this car. I am not saying you cant have more, I am saying for real daily drivability (sorry Hijinx, I still love you man), that is it. If I am blowing my tires off in first and second and not hooking up until I hit 3rd, party is already over.
For Jeff, and the others, 2nd stage is the sweet spot , which is not far from where I am and where I am going at the time. Look at Jeffs numbers, I said 250/250, hes making 200 and 280. The reason for the turbo swap is the factory turbo makes great torque quickly, but cant sustain it because its a smaller turbo. That's what a bigger turbo gives you, it allows you to sustain the power a little longer across the band.
I was like you, completely not expecting any of these bolt ons to do anything without a tune and I feel because of the 1.6 displacement of the smaller motor, I have been pleasantly surprised.
dyn085
There's a lot to hit up in this post so instead of separating it into a gazillion quotes I'll just post my responses within the quote in red.
What is not being considered here is the tune, not the parts. I keep bringing it up because it's applicable. I see the math you're trying to do and want to support it, but you're just not correct in how the tune works and obviously unaware that the programming uses the same framework between both the FoST and the FiST. And the Mustang. And the Fusion. And the normally-aspirated counterparts. Different functions are turned on or off on some of the different platforms, but the underlying framework is exactly the same.
In theory, I unequivocally agree that more air in should equal more air out, which would be an increase in mass air flow resulting in more fueling and more power. But again, you're not taking into account the tune. You speak towards what the tune 'can and cannot do on its own', but you actually don't know anything about it and I will give you some examples why in a bit. And this doesn't even take into account your statements in other threads towards MAF tuning, despite this being a MAP tuned platform.
I've already shown you a datalog of stage 3 parts on a stage 0 tune, along with some brief tips on what to compare and what's pertinent, in your other thread. Either you understand it and are completely off-base with your thoughts of your own car or you don't understand it and think what you're saying is correct.
And this is exactly what I continually say. If you're on the OEM turbo you can max out it's capabilities with an FMIC, DP/CBE (depending on whom you talk to), and a good custom tune.
That's solely dependent on the intake and turbo. @Hijinx has already shown us that an upgraded intake on an upgraded turbo is still a very high cost-per-hp modification that amounts to nearly nothing, but the 2J may have faired a bit better.
I'm not going to bag on you for how all of this is worded but I will definitely comment on the fact that I will question your tuning claims above due to it. And there's nothing wrong with reporting your findings (which is something that I highly encourage, recommend, and ask of members), but you have the capability of producing legitimate, objective information yet you don't. You take the one element that can confirm or deny your subjective opinion, exclude it from the conversation, then blame others for being wrong in their assessment.
Basically, you have the ability to prove people wrong but, just like Jeff, would rather not use it and would prefer that we just take you on your word.
You're not getting 250 whp without a big turbo. Furthermore, the correct BT choice would actually make this car even more drivable because it would eliminate blowing the tires off in low rpm and give more breathing room in the high rpm. Again, this makes sense to those that are already familiar with power curves, tuning, and reading compressor maps.
Your guess of 250/250 shows that you are completely unaware of what the OEM turbo can do. Your car isn't going to hit it without a BT upgrade, Jeff's car isn't, mine won't either. What a bigger turbo gives you is more traction (by limiting the low-rpm boost spike), a wider power band, better fuel mileage (if you can stay out of the GO pedal), and the ability to hit 250 whp or more.
Just collect a datalog on the stage 0 tune and post it up. I already posted mine to help show you but I don't think you're going to understand until you see it actually happen on your own car. Like I've told you and others, it's time to get familiar with torque-based tuning because it's significantly more different than what you are thinking.
I've created a lot of threads to try and help people learn how to datalog, troubleshoot, use V-Dyno, have ATR tuning discussions, etc., and the entire purpose of that was to help inform the community of how to collect, evaluate, and share their objective results. I don't know why people are trying so hard to have their 'word' simply be taken as gospel, just collect your pertinent data and share it. This community could be so much further informed if it just tried, but for some reason there's a group of people that would rather be known for opinions than legitimate data. Collect your data, load to Datazap, share, discuss-then everyone learns and all of the lessons we've learned in the last couple of years don't have to be learned again.
jeff
jeff
Thread Starter #216
Dyn085, you keep talking about collecting data as if your one virtual dyno is the end of discussion proof and nobody else's data matters. As I keep saying there are so many opinions of experienced tuners along with dyno runs that conflict with your one virtual dyno of "proof".
Hijinx, I see you have returned although you said you did not want to be part of this. Welcome back. Middle of the night and you guys have nothing better to do than search the forums for someone to bully.
It is now my belief that you visited my user page (saw that, thanks!) and build thread, saw that someone is happy, has nice cars, a nice house, a gorgeous wife, and is happy with his fiesta ST without presumably running up high interest credit cards to the tune of thousands of dollars on mods as you have, and are jealous or angry because you cannot enjoy your car as your endless quest for the most HP eludes you and consumes you and causes you to search the Internet in the middle of the night for answers and satisfaction, arriving at none except a small adrenalin rush when you mock and laugh at and put others down continually because you need some sort of affirmation for yourself.
I have said over and over, I respect your opinions and your love for cars, but you seriously need to grow up.
twolf
Well personally I'm up late because I'm my own boss and I prefer to work at night, when nobody is around to bother me.
I don't really like your presumptions, I'm a full time college student with a full time job and the only thing on my car that wasn't bought outright was the car itself... just because you can't afford to modify your car without credit cards doesn't mean the same for the rest of us.
Not really cool to sit here and brag, but your presumption was so far out of left field and your bragging so unnecessary... nobody cares about your kids... your wife... your house... your cars... well except the Fiesta, so stop taking things so personal and just stop replying... this damn thread has gone on far too long.
Jeff, if you are really willing to stand behind your choice to defend the intake, my tuner will let us run our cars back to back on his dyno, I will re-install the stock intake and still make more power than you, on 93 octane. I can /promise/ you that.
Edit: also, I'm done replying to this thread, I'm not going to participate in personal attacks and that's what this is devolving into.
jeff
jeff
Thread Starter #218
twolf,
My assumption is because people criticized me earlier on this thread for my age and religion when it has nothing to do with this discussion nor ever came up, they only got that info from other threads or my user page. Obviously in their case it has more to do with cars if they add that to the mix.
You are young and in college and have a great future I am sure. I really enjoy reading your posts and seeing your passion for life. I enjoy your build thread and respect your choices. Some friendly advice, don't be so sure of yourself, you can learn that the easy way or the hard way, or never at all. It is possible that you are wrong. It is possible that I am wrong. It comes down to a difference of opinion and what data we are believing. In the midst of all of that, I can continue to agree to disagree, but my point above was that there is no need for people to continually find me and criticize me just because I don't agree with them.
I appreciate the offer on the dyno, but I have no desire to do that, nor do I need to "make more power" than anyone, for me this is not a race to see who has the biggest penis. I'm just a guy who loves his car and is trying to share his experience with others.
And by the way, some people do care about more than Fiestas and horsepower. I have made many good friends over the years, our friendships began with a mutual interest in cars and modding but evolved into real lasting relationships based more on things that matter. Life is about more than cars, the older you get you realize that cars are cool but people might be a little or a lot more important.
twolf
I was just pointing out that we are on a car forum. I personally don't care what cars you have in the garage... how hot your wife is... the fact that your kids just got honor roll... this isn't Facebook, this is a Fiesta ST forum and that is what most people come here to look at.
I did not see anybody bring up your age or religion, because I've been slammed with work and off of the forums for a week or two... haven't read the stuff I missed.
I made the dyno offer because I'm confident in my opinion. Not because I'm trying to dick measure, I just want this conversation to end. If I had a CPE intake (which I might get one day because they sure are pretty) I would do the tests myself and finally put this horrific argument to rest (but it would be pointless, because this is the nature of car forums. No matter what you say, what you post, or what proof you give there's always somebody there to argue the opposite)
I wish this thread would just get locked at this point, there is nothing constructive coming out of it, it's just repetition of stuff that has been covered/posted about 500x thus far.
Bottom line?
I'm happy with my car, you're happy with your car. I'm done trying to convince you you're wrong, or that I'm right, or whatever.
I mean even though I think an intake is probably the lowest performance to dollar ratio mod you can get, at least you drive a ST and not a GTI or base Fiesta or something.
Let's all just shut up.
Yea, I enjoyed the "penis envy" comment (not really, it made no sense). I read Twolf's post as offering you the chance to show that the intake claim was wrong or right and gathering some of the data you keep talking about.
I personally don't see much benefit to this since it's assumptions on both sides, whether you admit that you have done your fair share of it or not. But what do I know, just a modder that has no credit card bills and bought his ST in cash (which you seem to think about anyone with "expensive" mods)
