Actually, let me start this by saying Jerricks customer service is awesome! I ordered these last week, Monday I believe. Anyway, shipping number came out and I was like sweet. But then, a couple days went by and the package hadn't been picked up from the warehouse. So I sent Jerrick a PM here asking if he could look into it. I'm still not sure if Jerrick saw it, or if he reached out on his own. But, that's neither here nor there. The point is that he got right on it by informing me. Next thing I know, Jerrick's telling me a set is gonna be shipped out from the UK warehouse on air. Not only did it go out air, but it went out Express! It only took 3 business days for my coilovers to arrive. To me, that's damn impressive and above and beyond.
Here are some measurements I took while installing. Pictures can be found in my thread.
Meister Measurements OOTB:
Method... Originally measured in 32nds of inches with a...uhh, a ruler, and patience.
Rear:
Start: 36mm
End: 45mm
Adj: 9mm
Front:
Start: 41mm
End: 45mm
Adj: 4mm
Driver Side Damper:
Start: -8
End: -10
Passenger Side Damper:
Start -9
End -10
Rear (both):
Start: -8
End: -12
Ride Height:
Method: Measured from highest point of wheel well at fender to center of center cap.
OEM Static Ride Height:
Front: ~ 337mm
Rear: ~ 343mm
OEM Droop:
Front: ~ 438mm
Rear: ~ 419mm
Meister Droop:
Front: ~ 378mm
Rear: ~ 368mm
Meister Static Ride Height:
Front: ~ 324mm
Rear: ~ 337mm
In inches:
Front: 13.25" -> 12.75" ( .50" )
Rear: 13.5" -> 13.25" ( .25" )
As long as it doesn't settle too much, it'll be right where I want it! Based on pictures, Meisters manual and knowing the drop amount I wanted, I gambled with the adjustments I made prior to installing.
Weights:
Method: Weighed myself in clothing, then held front to get measurement, then held rear to get measurement.
Hijinx: 234.4 lbs
Hijinx w/ OEM Front: 245.6 lbs
Hijinx w/ Meister: 248.6 lbs
Difference:  -3 lbs
Hijinx w/ OEM Rear: 241.2
Hijinx w/ Meister Rear: 242.4
Difference: +1.2 lbs
OEM Front: 11.2 lbs
OEM Rear: 6.8 lbs
Meister Front: 8.6 lbs
Meister Rear: 8 lbs
So, both fortunately and unfortunately only a 1.8 lbs loss. But, that wasn't the goal.
Edit - I went with -1.5 camber.
Edit - Changed terminology for clarification.
Scent from Glade Air Freshener
