Our top mounts are slotted so, with the car up and top mount loose, you'd pull the coil outwards for a DD in the interest of tire longevity. The idea is tighten while wheels are up to set the camber best you can. Then set it on the ground gently for final torque. I've always done it that way so the weight of the car can mitigate the movement of the mount while i gave the nuts their final torque down. I admit this may be overkill but if you set it on the ground completely loose, the coils will likely lean inward (negative camber) under the weight. The lean will be random and obviously different for each side. Even so, as long as you tightened them properly, that shouldn't be the cause for your clunk. If you didn't use a pass through ratchet for the end links, they may be just loose enough to shift under certain loads.
And like Jerrick mentioned, tightening certain things unladen can be problematic. I use a jack under the control arm and jack it up until it's parallel to the ground and THEN tighten the top mount AND end links. This positions all the parts closer to what they will be under driving conditions. This goes doubly if doing the 2pt brace.
	![Smile    [:)] [:)]](/images/smilies/smile.png)
![Really Confused    [???:)] [???:)]](/images/smilies/confused.gif)
![Big Grin    [biggrin] [biggrin]](/images/smilies/biggrin.gif)
![Wink    [wink] [wink]](/images/smilies/wink.gif)
