For Sale: Evap Check Valve for 2016 Intake Swap
Trader history for SFP (0)
Status
Not open for further replies.
SFP
Coolville
Here is a spare check valve setup I made for the 2016 to stop evap related P144c
I have been running this with an Injen intake for 9000 miles with no issues.
SOLD!!!!!!!!!!!!!!!!!!!!!
This is the revised setup I did with braided lines which is the only reason I am selling this.
You simply cap the boost line and put this in place of the other it has the factory connector on it.
SFP
SFP
Coolville
what does the boost line serve as if you can just cap it?
It's there to help pull evap emissions when there isn't a high pressure on either manifold or intake to push/pull them. It's not needed if you use this.
Brooklyn
I can't seem to grasp why these bigger companies can't just build a R&R line for the 2016.. lol... I don't have an intake yet so I dont need this line, but I am looking into it. thanks for the info :)
SFP
SFP
Coolville
Well this setup works perfect so just let me know if you want it.
I just used a vacuum cap on a quick connector, you can use the vacuum cap directly on the line nipple and a hose clamp over it.
Status
