Razor, giving enough miles on consistent fuel, and climate, would the fiesta self tune its self to 98% maximum power timing wise ? Or would it always just run that max of 6*?
6* is the max in the stock programming and COBB OTS programming. There is also a base, floor and ceiling in the ignition timing strategy. You can log these to see where the ECU is running in relation to these.
The dynamic timing is very much real-time. The OAR system is more a learning system and directly rates to how the ECU applies adaptive dynamic tuning learned over time.
For those in the mid-west USA stuck with 91 octane piss-water, I can tell you for sure that the "NOS" brand octane booster works very well to reduce the negative timing corrections. It is technically not legal for "street" use however.
I was using Esso 91 or 93 where I could get it to use up my gas card that I got as a bonus with my purchase. Now I only fill on Ultra 94 from Petro-Canada.
Cost factor wise for me it's not worth the savings since I don't drive it that much. Figured an average commuter can save about $1.50-2.00 per fill-up per week by going to reg. unleaded. At the end of year you save about $75-$100.
At current prices the difference in my area is around .70 cents a gallon. That's approx 8 dollars a fill up ( 11 gallons plus each fill up). I drive a lot so I fill up 2 to 3 times a week. Bought my car June 14 and already have 19,000 miles. End of the year we're talking over $1,000 saved by running 87. I will start running 93 when I get a tune.
