Verifying RMM is installed correctly?
Hi all,
I got my '14 used, and it came with a Cobb RMM already installed.
I still have some of the 1-2 clunk, which people say the RMM helps alleviate.
I've peeked at it when it was up on a lift, but didn't see anything obviously amiss.
What would be the procedure next time it is up to make sure it is installed correctly?
Thanks.
-L
CanadianGuy
When you say clunk do you mean the sound or the transmission gear shifting feeling?
If sound check the tip motor mounts. Loose bolts or worse would have a similar affect.
If tranny think to replace the fluid. Helps a lot.
L
There's no weird sound, it is just the feeling in pedal/hand/butt. 1-2 just feels clunky/sloppy, sort of as described by lots of people, but I figured having the RMM on would alleviate it.
Planning on doing trans fluid soon, will probably go with the Motul 300 everyone recommends.
Thanks!
CanadianGuy
Well it is a dual mass flywheel could be that as well.
You might also check the torquing on the bolt that holds the RMM. It is supposed to be 50. There is also a nylon (?) washer that comes with the RMM. )
L
Thanks. I did check that the nylon washer was there visually when I had it on stands to do brakes last week. I should have it on a lift this spring with access to a decent torque wrench and will check the bolts.
Hi all,
Thanks.
-L
Clunk? I understand it helps with the slamming of the engine against the firewall. 1-2 is the biggest change in gear ratio. This is the shift that typically breaks stuff. Does the engine feel as tho is is wobbling back and forth like before?
L
Thanks for posting, reminded me to followup on this.
I've got a friend who is a much better driver than I am who helped me diagnose this. I've always thought the clutch should be very binary, in or out, don't ride it except 0-1. The 1-2 shift in the FiST is more like going going into first. You have to be slower on the clutch out. Concentrating on that for a week, rewriting my muscle memory, fixed this problem.
