Auxbeam LED bulbs
Looks great!
Do they come in 4300k? I would like a set that doesn't light up blue.
zanethan
That glare looks awful :(
I think his camera is amplifying the glare quite a bit. It really isn't that bad in person.
I have yet to have anyone flash me for them being too bright and I've probably driven past thousands of people at this point.
Installed my headlights today, no issue getting either side installed will update thread in a week or so with my thoughts as well.
So the H11's will fit the stock USDM headlight? I just want to be clear because better bulbs sound great to me
Yup direct replacement same bulb for fogs as well
TUX15ST
Are you guys having to make any adjustments to the beam pattern, like lining them up so they are even or pointing them more at the ground etc? Or are you plugging them in and they are perfect?
TUX15ST
So who had issues with the passenger side fitting in the housing and what was the solution?
Just pulled the trigger, I'll post a review when I get them
I pulled my headlights completely off and had no issue. was way to cold to do it outside.
TUX15ST
#35
Ok ill have to report back on my 15 friday or sunday
ndaniels
I'm trying to install these in my '15 and cannot get the passenger side to fit. Someone mentioned adjusting the headlight, but our headlights are not adjustable horizontally.
Anyone have any luck with a '15?
ndaniels
Yes, completely out of the car (and on my living room floor).
TUX15ST
#39
how did you get these to fit? The fan housing is too large to actually lock into place
**edit
i now see why the video only shows the drivers side instal.
The passenger side light has to be adjusted all the way in for it to fit. You can then readjust once the bulb is in.
what was your solution? How did you "adjust them down"?
