Ford recalls 440k vehicles due to fire risk
It’s not really a “fix”. The coolant will still burn off. This is so you are aware it’s disappearing and to lessen the chance of fire. Coolant loss shouldn’t be happening on a modern car.
jmrtsus
It's just a sensor and new hoses right? ..to band-aid poor cooling passage in the head, or am I reading it wrong.
Sent from my ONEPLUS A3000 using Tapatalk
I think you are reading it wrong....
Best way to determine effectiveness would be to get some localized before and after temps. (infrared temp gun?)
Absent of that, we may be able to get some sense by comparing the altered coolant exchange flow rates/volumes using external lines and valves, to the changes in the 2016+ heads. (which probably also had some external changes) Effective or ineffectiveness of the changes aside, if you have a hot spot, diverting and altering coolant flows is what you need to do to begin to address it.
I merely skimmed it but they're also allowing time for compression testing, cooling system pressure testing, checking stored codes on overheat, stalls, (indications of abuse,) and performing some tear-down in order to inspect the backside of the engine.
I guess you could simplify it down to that. New coolant bottle design with piping, wiring harness to go with the coolant level sensor, rerouted turbo coolant plumbing and a few more odds and ends to hold it all together.
But essentially, yes, this is just "workaround" for the design defect in the older cylinder heads.
I have to admit... that’s a way more involved fix than I predicted. Personally, changing the flow rate etc should fix the issue. I really expected ford to just shrugge their shoulders and wait for repairs to start rolling in on the customers dime. Happy to admit, it seems I was wrong. Good for ford !! (Finally)
me32
Glad to see some positive feedback
GAbOS
He didnt actually read the pdf. Thats why he doesnt know.
Bottle, sensor, wiring for sensor and fluid. I read it just fine.
Who cares how much stuff they have to remove. Fact is they are issuing stuff to do it. Fact is they are doing something about it. It's called standing behind the product and not telling the customer to take a hike.
Or are you just surprised? It sounds like your freaked? If not excuse my response.
Are you serious? My comment was in regard to the nearly 60 page PDF illustrating the installation of the sensor. Not sure what you think you read.
So you are criticizing them for being thorough? I glanced over it. It looked like you had to remove quite a few things to get to the area to change it out. Have you worked on Modern cars much? It's pretty much par for the course. Also again I repeat why do you care, are you a Ford Tech? A Ford Tech who is bemoaning the amount of recall warranty work he might have to do?
As far as I am concerned from a customers perspective they are doing the work not I, so what is the issue? Seriously you are making a mountain out of a molehill here. Lol
My big concern is that every time I have taken my car in for service they have screwed up something. Now I may be a bit pickier than the average ford owner but I find it unacceptable to find bolt heads that are stripped, plastic screws that are never replaced, inner painted panels to have all the paint scratched off.
With this amount of work its a ton of opportunity for these Monkey's with wrenches to screw more stuff up.
me32
Different dealer?
Suggest that we watch the 2013-15 Escape, Fusion and Transit Connect forums for feedback on how well the latest attempt at repair may (or may not) address the issue. It seems they initially tried to patch this using software ([:0]). [scratch] I see the source of the cynicism. Big corps move slow and it often takes a year (or few) for them to really finalize on anything.
Maybe we should seed a dedicated thread titled: "FEEDBACK: Your Recall Work"
...or maybe more specific, "FEEDBACK: Your 1.6L Engine Recall Work"
...in each of the forums and see what the cat drags in...
Escape:
https://www.google.com/search?q=site:fordescape.org+recall+coolant
https://www.google.com/search?q=site:fordescape.org+recall+overheat
http://www.fordescape.org/forum/engine-technical-discussion/86386-coolant-disappearance-2.html
Fusion:
https://www.google.com/search?q=site:fordfusionforum.com+recall+coolant
https://www.google.com/search?q=site:fordfusionforum.com+recall+overheat
https://www.google.com/search?q=site:fordfusion.net+recall+coolant
https://www.google.com/search?q=site:fordfusion.net+recall+overheat
Transit
https://www.google.com/search?q=site:fordtransitusaforum.com+recall+coolant
https://www.google.com/search?q=site:fordtransitusaforum.com+recall+overheat
https://www.google.com/search?q=site:fordtransit.org+recall+coolant
https://www.google.com/search?q=site:fordtransit.org+recall+overheat
me32
Escape:
Fusion:
Transit
Great idea
I have tried 3 with the same experience. They just may hire hacks in my area.
me32
Sorry to hear that. See if any other st owners that might live in a 50mile radius can reccomend a good dealer
jmrtsus
Should we hand the bill to FoMoCo? They’re changing all the RS motors. I suppose that’s far less numbers than the defective 1.6 though.
What defective 1.6 are you talking about? The overheating problem? I was under the impression this recall corrected that by adding a coolant level light to the affected engines worldwide. Did I miss something new about defective engines?
GAbOS
The issue is the effected vehicles have a localized heating issue in a single cooling passage in the head. The design flaw was later corrected. We are not getting the new head, just a dummy light that tells us we're doomed. [emoji16]
