Mashup: Turbomac and Titan = Perfection
I've been looking at these for about a week but can't find any info on wheel weight. Can you stick one of those you've got in the basement on a scale?
Yep will do! Except it's gonna be a couple weeks before I get home.
Two things I've noticed is that they really stretch those 215 Kuhmos the OP has; I was hoping to put my stock 205's on to finish the tread off on those for the summer but that might be real tight.
Also the steel grey has a bit of a gold tinge to it at different angles; hoping they look good on my Magnetic!
Some brighter pictures, sunny day vs. overcast...
Looks good. Curious for a brake dust report after a few days. Wondering if those small outer pockets will get any dust.
Sent from my SM-N920V using Tapatalk
kona16
Thread Starter #24
Like all wheels on a FiST...there is brake dust. Can't get away from that and cleaning will be a bit of a chore but worth it to me, not that much of a big deal just a little more time spent...
I have been eyeing these wheels for a while. Finally somone has pictures on a Fist. I think these are the wheels for me !! Do they come in bronze ?
kona16
Thread Starter #26
Nightcrew13, the 215's on the car have rim protection with a 8.6" section width and 7.5" tread width, manufacturer says it fits 7" - 8.5" wheel so not really a stretch. You don't want too wide of a tread width or you may rub depending on your suspension set up. You can run the stock 205's on an 8", others here have done it. Also, I don't see any gold, pretty much silver metal flake...if anything it is brake dust making it off color...lol! Should look fine on Magnetic.
kona16
Thread Starter #27
I have only seen Steel Gray (mine), White and Magnesium Black (flat dark grayish).
Ok thanks. I messaged the seller on ebay if they have bronze. Waiting for the reply.
I found gold on eBay.
Those wheels transform the whole look of the car (for the better) over the factory rollers, and most other wheels out there! [twothumb]
The flat black would look wicked on a magnetic!!
kona16
Thread Starter #33
Just saw a posted weight by an Ebay seller at 18.43 lbs.
#35
Double thumbs up from me. Reminds me of one of my favs, CCW D11L, but you get four for 700 instead of one
#36
I forgot all about those CCWs, which (depending on who had that style out on the market FIRST [dunno]) are a copy of the Enkei NT-03 series.
IF I could ever afford CCWs, it would either be those, or their C10s, in a matte black/dark graphite color. ;)
#37
Hi, quick question how long have you had the mountune springs on the car ? Just worried about any rub issues after the springs settle.
TIA!
shouldbeasy
#38
... and I just bought the silver set on eBay. I had to! They 'match' my Mercedes-Benz Sprinter wheels! Now when I tow the FiST everything will match except the tow dolly wheels.
They're just too perfect for my rally inspired build - weight of them be damned. I've turned a new leaf and am sacrificing performance for looks!
Finding some local sucker to buy my gravel trashed wheels was the push I needed to pull the trigger. Thanks [MENTION=5751]letitreign[/MENTION]
kona16
Thread Starter #39
TIA!
It has been around a year so they are done settling. No rub issue, depends on what tires you are going to run. I have 215/40 x 17 with a 8.6" section width and 7.5" tread width with no issues. Make sure to check because all tires are not created equal, even in the same size.
#40
Ok thanks.i was thinking of the riken raptor tires. 8.6 section width and 7.4 tread width. Mainly for the very cheap price
