Mashup: Turbomac and Titan = Perfection
#61
The Federal 595 Evos, including shipping, are a good deal less costly than those Kumhos (even after the current rebates), and at 240 tread wear, are not a track type tire by any means (and actually have a decent water evacuating tread pattern), although they probably will wear quicker than the 400 tread wear PS31s.
Being .5" wider in tread width, (but only .1" wider in section width, and .1" shorter in height) I can see where you might fear some rubbing with a 40 ET, as even I might be close with a 42 ET using the Evos on my wheels.
kona16
Thread Starter #62
I just was leaning on the safe side, rubbing was my biggest concern. I saw others on the site that had 38mm - 40mm offset with around 8" wide tread width tires that had issues so went a little narrower. Also being on lowering springs and not coilovers, I didn't have any way to adjust ride height...safe than sorry...
shouldbeasy
#63
225/45R17 Mounted on Rota Recce 17x8 +40 - Simply perfect.
Goose
hey kona16, what is the rear wing extension you have? It looks great.
kona16
Thread Starter #65
Maxton Design...front splitter and rear wing extension. Ordered directly from them and received the order quickly.
kona16
Thread Starter #67
Goose
They look so good! Did you have those center caps custom painted or are they from another model or something?
kona16
Thread Starter #71
They are metal stickers that I found on eBay. Really good quality, made to fit some other Ford center caps. Bent them slightly to fit the curve of the caps, alcohol wiped, heated them up a bit with a hairdryer and applied them.
kona16
Thread Starter #73
Thanks kgfrew...still about the same since then. Just waiting on Bilstein fronts...and waiting...and waiting...
kona16
Thread Starter #74
Been waiting so long...I mean rears...lol...
#76
I feel your pain. Been holding off on the springs until the rear shocks arrive, but now I'm feeling antsy, since these guys are now saying May on those. Thinking of putting in the springs and front struts tomorrow.
