Help or advice needed please
Hey. Help - girl in need of assistance!! My 2013 ST2 I had remapped a few months ago and it's been absolutely fine up until yesterday when the weather has got much better and I can't get any power above 2,500 revs?? Foot to the floor and nothing happens. I pretty much can't drive it at the moment. Normally I can pull out of junctions and fly but darent as I have no power whatsoever. Guy who did remap says to get it plugged into diagnostics to see what's up with it. I have no warning lights on the dash. Anyone got any ideas? Ta. One unhappy girly.
zanethan
Sounds like it's in limp mode. Unloading then reloading the map might resolve the issue.
You mentioned that a guy did the remap, did he tune it himself? If so I'm suspecting a possible bad tune.
Maybe a charge pipe got blown off since there is now warning lights?
S
Thanks guys. Yea the guy who did the remap has offered to reset it and plug it into diagnostics. Like you say it seems to be in limp mode. Just can't drive it till the weekend and even then it'll be a little dodgy lol.
CanadianGuy
As an alternative view Did you select Eco map by mistake? Which would limit power a lot.
S
What do you mean did I select eco map? Sorry - typical girl lol...!?
CanadianGuy
Via the cruise control buttons if using Cobb ap you can toggle between 4 maps. I don't have the link handy but a quick search on the internet you should be able to find map switch for Ford and Cobb.
S
I don't have cruise control.
CanadianGuy
Huh? Never though it was an option. Here is how it works.
[video=youtube;vmvqXnQ48pg]https://www.youtube.com/watch?v=vmvqXnQ48pg[/video]
zanethan
She's in the U.K. they have completely different options than we do in N.A.
From what I can tell she doesn't have an AP either.
CanadianGuy
Well there you go I'm an idiot for not reading everything lol . So scratch that idea.
S
Nope. Don't have any of that. Plugged diagnostics in last night and no codes came up either which would be consistent with no warning light! I'm not driving it as it is at the mo so my only option after work later is to drive it out a few miles and call out the recovery - see if they can diagnose it at the roadside lol.
CanadianGuy
Could be a boost leak or similar. Symptoms are similar and low boost pressure would not trigger any codes. Do you still have the sound symposer installled? It can be a source of leak if the internal diagram broke. you would not really hear a difference or the leak.
S
Took it down to the local garage yesterday morning first thing and it was perfectly fine!!! It's ok when it's cole or the wether is cold. When went to use it again after it had been stood in the heat all day same thing again. Garage phoned Ford who think it might be the temperature sensor on the dash and they were gunna get back to the garage but they didn't. Thanks Ford!!
S
Ok so latest update. It's been with local ford dealer for past four days who said it came up with a code saying it was the fuel pump. I'm no mechanic but said didn't believe it. But the insisted and it was gunna cost me £500 nearly all in. They fitted it and then rang me yesterday and said they done it but that wasn't the cause of the problem!! Boom!!! Told em so!!! So they're now keeping it for the weekend. Sent a report off to top ford place and wait their response. Me not happy!!! They also wanted to charge me for the fuel pump etc. Not a chance!!! Finally got a courtesy car out of them - they didn't wanna give one to me originally - so I've currently got a 1.0 Ecoboost!! Nippy little thing but ITS NOT MY BABY!!!! So not happy hunny!!! Not driven it for over a week now - think I need help!! Lol.
What DO you use to flash your tunes?
Valet mode?
S
I'm in the UK... so dunno what you mean.
S
Thread Starter #18
Ford still have it. They still dunno what's wrong with it. They wanna keep it till the 20th when they can get a tech guy in from Daventry up to have a look at it. Had enough now so complaint gone in. Waiting to hear from General Manager! ????????????
zanethan
Anytime a tune is changed it's known as flashing. So what did your friend use to load on the tune?
Did you ever return the ECU to stock? If not you need to start there.
I said this in the beginning but I'll say it again. I'm suspecting the tune. It's possible that the ECU is misreading the ambient or intake temps and sending the car into limp mode when it is warmer out.
You need to return the ECU to its stock configuration so that the tune can be either ruled out or confirmed as the problem. If the problem is gone once returned to stock then the issue was with the tune. If the problem remains once flashed back to stock then we can rule out the tune as the issue. Given that this issue didn't exist before the tune, in my opinion, you need to start your trouble shooting there before throwing money at parts.
S
Thread Starter #20
Ok so a month later and I've had to have the whole ECU replaced due to internal failure. Nothing to do with the remap. It's cost me an arm and a leg and I'm complaining big time to the CEO of Ford !!
