Lowering the steering wheel angle
codestp202
CA
Has anyone, or does anyone know if its possible to lower the angle of the steering wheel beyond the stock adjustments? After hard mounting my seat to the floor for the half cage, I want just a little bit more adjustment for the steering wheel to angle down towards me.
Any suggestions would be appreciated!!
zanethan
Charlotte
My guess is that it would be far easier to lift up your seat a little more than it is to alter the angle of the searing wheel.
codestp202
codestp202
CA
I'm not really in a position to mess with the seat height as the angle of my 6 point harnesses may be at an improper angle to the harness bar. So I'm seeing if I can get maybe 10 more degrees more out of the wheel.
NC
Is it possible to remove a shim/spacer to lower the column mount point to the dash beam?
I'm having issues with high angle on lowest setting - frustrating!
Spring, TX
A slightly smaller wheel and a bit more downward adjustment. 2 of my few 'complaints' on the FiST
