whoosh motorsports shop car day....goodies installed with pics :))))))
KnockOff
Could you get a pic of how close to the ground the filter is on that intake? The cold air on my older focus would try to get water in it while driving in heavy rain. Could not go wot a couple times. Acted like there was water vapors in the chamber or something. It would cut power and studder. Not like hydro lock. Only hapoend a couple times but it's something I worry about now when it comes to filter location.
ron@whoosh
ron@whoosh
Vendor
Thread Starter #22
I can and will do that for you
The car will need to be up to within inches of the headlight to touch the filter which is some pretty deep water even if lowered
TDavis
Hopefully the K sport brakes might be installed?
Woods247
I was getting to your answer - sorry about that Woods247
It's a flat panel foam filter that does in fact pull from the fender. It is very loud. Another member had said it's close to the 2J cowl intake in terms of sound volume. I'm starting to BELIEVE!
haha
Ron, how are your intake temps compared to stock?
ron@whoosh
ron@whoosh
Vendor
Thread Starter #27
Whoosh Motorsports needs to make a Cat-Back... your down pipes look great so thinking with your knowledge and your contacts a Cat-Back from you that sounds as good as your number one best seller at a cost of 400-500 would be sweet.
thank you
we have one in the works
