215/45/R17 Rubbing
kivnul
So I installed new wheels and tires last night. After a trip around the block had noise in the back. The fender liner on the rears was drooping and I tightened them up with a screw/washer on each side. Drove to work this morning to break them in and I got some noise on a couple of very hard corners. Currently running:
Team Dynamics Pro Race 1.2, 17x7.5 / 45mm offset
Bridgestone RE71R 215/45/R17
I don't think its fender lip rubbing but I will look at it in depth to check it out. I have heard that there is a tab that connects the front bumper to the fender, I will also look at that. Does anyone else know of things I should look at? It has been suggested that I coat parts that I think are hitting with grease to see if it is still there after I get it to rub again. Is there a better method? This is my first try at running oversize tires and there is an autocross this weekend I would like to run these on. Tomorrow will be a nice day after work but it looks like torrential rain for the rest of the week that will severely curb my ability to find the problem. Also doesn't help that I live in the sticks on dirt roads, have to travel a bit just to hit pavement. Thanks in advance for the advice.
I've had 215/45r17 RE71Rs on srock rims for about 10,000 miles and stock suspension, and they have actually worn holes in the rear fender liners. As for the front, I hear it scrub at nearly full lock in combination with a bump. Unfortunately I still see no signs of where it's rubbing in the front, kind of strange honestly. I'm not super concerned as they are coming off soon and being replaced with 245/35r17s when I get my fenders trimmed and flares on.
Which wheels and flares did you choose? I want to eventually do something like that too, so I'm curious.
DaveG99
215/40/17 wont rub. Get a smaller tire.
kivnul
kivnul
Oh, if the RE71R's came in that size I would be on them like white on rice. I think I found a rub spot on the hard plastic linings. I will take some photos tonight when I take the front wheels off and take a heat gun to the plastic.
kivnul
kivnul
Update. So I took off the front drivers wheel and found 3 spots of rubbing on the fender liner. I took a heat gun to the plastic and when it was pliable I pushed at it to get it to form closer to the underlying metal and let it cool.
Car macro view
Horrible photo showing main rub spot up front
Two additional rub spots
After melting and pushing. Passenger side turned out better but no photo
Screw placed to hold up felt rear wheel liner
AutoX this weekend, will report back if I hear anything.
BRGT350
I wouldn't be surprised if they will still rub when autocrossing. The suspension is articulated much further on course than on the street. I tried fitting a set of P215/45 17 tires on the European Fiesta I had for the Fiesta Movement and decided they weren't going to work. That car sat higher than the factory ST's, and there just wasn't enough clearance for them. I have problems with my P205/45 17 tires on my lowered ST and need to start working on spacers for the springs. The rear fender liners are pulled to maximize clearance and the front bumper cover is trimmed. It is far closer to rubbing that I would like. P215/40 17 is the perfect size for the ST, but there just aren't a lot of tires in that size.
kivnul
kivnul
I wouldn't be surprised if they will still rub when autocrossing....
Yup, they will still rub, I am just trying to reduce it as much as possible. I drove over to a location that rubbed yesterday and I still got rubbing but it was much reduced. I think there is another spot in the wheel well that I may need to trim, this one more of a tab. It is sharper and could cut a tire unlike the previously shown spots. I will yank the tires again tonight and start round 2. This odyssey is mostly for other folks to know what to look at. I did quite a bit of forum searching and never saw photos nor really good descriptions of rubbing locations. Some folks run this size tire and quote no problems but I am guessing they mostly DD the setup and wouldn't notice anything except speed bumps or something similar..
I almost bought some 215/40 R17 Federal RS/R's for AutoX but I'm not 100% sold on their quality. More options that size would make for much happiness.
Me too but I want someone to install them for me and I want raw carbon fiber bits as my car is black.
neeqness
A 215/40 17 shouldn't rub at stock height but might lowered depending on the lowered height. 205/45 17 should also work at stock height but it will be really close to rubbing. If you autocross it might rub a little. When I ran it I think I only had it rub once but I partially consider it my fault as it was a dip on the freeway that I didn't notice and hit too fast. Never had problems hitting the dip (or anywhere else) at other times. 215/45 17 is pretty much guaranteed to rub even at stock height on all but the best of roads at conservative speeds.
Have you considered a 16" or 15" wheel?
kivnul
kivnul
With the $ I have invested so far on the 17" wheels and tires, I am certain my wife would kill me if pick up another whole set. I am somewhat committed to trying to make this work. If all else fails, the RE71R's will become my DD tires (my forearms will become huge do to the tires pulling this way and that with the roadway. My tinitus will be much worse =) and I can run the stockers as my AutoX set.
