Is it normal for catch can's PCV hoses to collapse under vacuum pressure?
green_henry
Pleasant Hill, CA
I have a Radium catch can and have never bothered to look at it with the engine running until today (while bleeding the air from my new radiator). When the engine is off, everything seems hunky dory, but as soon as it starts, the PCV hoses to/from the catch can collapse because of the vacuum. I used the hose that shipped with the kit and it's only a few months old. Is this normal?
ron@whoosh
Vendor
Las Vegas
no, that actually isn't
I've pinged my Radium contact - I'll report back
felopr
JD
No they shouldn't collapse. My only way that would happened is if you install the in-hose checkvalve backwards but this kit doesn't have one.
I have a Damond Motorsports one and doesn't collapse. Those hoses are super strong, i think they are hydraulic rubber hoses
G
green_henry
Pleasant Hill, CA
Thanks for the feedback. Everything seems to run ok but it definitely doesn't look right.
For whatever it's worth, the kit shipped with Dayco 5/8" ID Fuel Line. I was surprised by how strong the vacuum is, so I can see why OEM is plastic instead of rubber.
felopr
JD
vaccum is like 20 in/hg at idle , and like 25 in/hg while on decel engine braking
I think they use plastic because is cheaper for them to mold it those curves instead of using a good vacuum safe line
and cant really use a silicone hose for that since oil permeates the silicone hose
Quisp
Davenport
Tell Mishimoto that. Lol
G
green_henry
Pleasant Hill, CA
I contacted Radium via email today and they acknowledged that they have heard the same complaint. They are looking into alternative hose materials, and I hope to hear back from them soon.
If you have one, another thing to check is the dipstick. I noticed that the stick was loose and was starting to unthread from knob. That's probably the downside of it being attached to the motor mount -- the vibration almost certainly made it come loose. I'll be putting some loctite on that tomorrow; easy fix
G
green_henry
Pleasant Hill, CA
After surfing the web for a few hours, I'm thinking that the 5/8" hose is too big and needs to be dialed down to 1/2" (which will require new fittings). 5/8 vacuum ratings (where listed) are ~15 in. hg. whereas 1/2 jump to ~28 in. hg.
felopr
JD
Care to explain more? You saw the dipstick not flush all the way down?
felopr
JD
My kit uses the factory fittings, is just plug and play imo. I think the error was to use fuel lines instead of harder ones like hydraulic lines
G
green_henry
Pleasant Hill, CA
As I was wiping off the dipstick, it felt a little loose and had clearly started unthreading itself. I tightened it back up and it was solid again, but I'm definitely going to put some loctite on it.
a1b3d0
Los Angeles
Did you end up replacing the supplied hose from Radium? On the Mountune website someone mentioned they received a replacement.
