180F Ford Motorcraft Thermostat now available
koozy
Took a month to get this little guy after placing my order as soon as I knew they were coming out, but it's now finally available from Ford Motorcraft for those that want to upgrade, but don't want to use the colder Mishimoto 160F thermostat. You can see that it's clearly stamped 82C on the thermostat, which equates to 179.6F.
Stock OE thermostat temp 90C/194F
Motorcraft thermostat temp 82C/179.6F
ron@whoosh
Vendor
awesome !
Part number?
felopr
part number?
If it wasn't such a pain to install tho...
part number?
Is there an echo in here?
koozy
koozy
updated first post with part #
koozy
koozy
I've gone over the install and I've convinced myself it's not that bad LOL [wrenchin]
felopr
I mean I haven't done it myself but looking the service manual, yeah...
how did you do it then?
alexrex20
man i want this but holy hell that install looks ridiculous.
edit: actually it looks like it would be easy to R&R by simply removing the alternator. hmmm
me32
Question. Is this made specifically for the 1.6 EcoBoost engine? Did this come from another ford vehicle line up? If so which one? Does anyone have a side by side pic on the stock and 180 tstat?
koozy
koozy
Thread Starter #18
it's made specifically for the FiST, specifically for the coolant level/excessive temp recall for affected '14-15' model years.
felopr
I haven't done it yet, but someone's done it without taking the whole front end off. the process while in tight confines, with the Ford Service manual procedure and the experience of others to supplement it seems doable.
http://www.fiestastforum.com/forum/threads/17205-How-to-Install-Mishimoto-Racing-Thermostat
yeah, I have the service manual and I know I had to remove the alternator to reach the housing.
Might as well and buy the thermostat and leave it secure in a place and change it out when I change the serpertine belt and pulleys
might as well and also put the lower radiator silicone hose that I bought a while back but couldn't change it because spacing is a pita
me32
Thank you for that info
