Clutch Still Sticking and Engaging when clutch petal fully pressed after replacing slave and clutch
Hey guys, a month a go my clutch petal started sticking to the floor but i would pop it back up. That last a week until i could no longer pop it back up and could no longer start the car. A small repair shop has replace the slave and the actual clutch but the problem is still there. Any help would be appreciated. Im outside of the bumper to bumper warranty. But since its not the slave or the clutch maybe I can still get it covered under powertrain.
TIA
TIA
Clutch/shift cables? [emoji848]
R
Before it went to the shop it started leaking a little brake fluid onto the clutch petal
How do the brakes feel? If the seal on the pushrod is going bad, you could be leaking brake fluid into the vacuum booster. Seeing as the vacuum booster/master cylinder are located in the vicinity of the clutch pedal (engine side, obviously) maybe have a look at that.
Isn't there also a pedal return spring on the pedal assembly? If so, is the spring still there? Does it look nice and tight, or worn and loose? Are the mounting points broken?
R
Brakes feel normal. The spring should be there it returns just fine in shifting gears 3-6. I'm going to try and replace the clutch master cylinder myself and bleed the system again and see if that works. The only ford dealership in 50 miles is booked up for 3 weeks.
Barf. Good luck, keep us posted with your findings!
R
Bleed the clutch. Fluid has white flakes in it. Bleed to clean fluid but still losing pressure when holding the clutch in for longer then 10 seconds. New clutch master cylinder next hopefully that's not to bad
